Go Back   Automotive Forums Car Chat > Dodge > Ram Pickup | Ram SRT10
Old 06-25-2005, 03:39 PM
Alan Freshman Alan Freshman is offline
1983 Dodge Ram 150 overheated and alternator belt jumped off
1983 Dodge Ram 150 overheated on me. I changed out the thermostat thinking that it must have gotten stuck. It has a new water pump. Alternator belt got tore up when it jumped during overheating. I don't know how to place belt on fan and alternator pulleys. I manuevered belt under fan blades and it there is no space to go into fan belt pulley.
I would welcome any diagram or advice on installing belt.
Old 06-27-2005, 08:34 AM
fredjacksonsan's Avatar
fredjacksonsan fredjacksonsan is offline
Caution: Monkeys bite!
Send a message via AIM to fredjacksonsan
Re: 1983 Dodge Ram 150 overheated and alternator belt jumped off
I don't have the routing diagram, but your belt likely goes around the bottom of the crankshaft pulley, around the alternator, then around the water pump/fan pulley then back to the crankshaft.
Make sure when you put it on that it's lined up, you have the older V-belts, so there will be multiple grooves on some of the pulleys.
As far as your overheating problem, I'd suspect the radiator. You can have it tested for flow at a radiator shop. Just a 10-20% flow restriction in your radiator can make a huge difference in cooling.
Ours: 2020 Jeep Wrangler 2.0, 53k
2013 Toyota FJ Cruiser, 84k
Kids: 2005 Honda CRV, 228k
