Old 06-25-2005, 03:26 PM
phantomgreen54 phantomgreen54 is offline
changing rear drum brakes
Passenger side rear brake sticks from time to time. I have decided to change the rear drum brakes. I have never messed with drum brakes before, any help would be appreciated.
Old 06-25-2005, 08:56 PM
big dude1 big dude1 is offline
i advise you to take a picture of the whole assembly to use it for reference... maybe put some paint stripes on the springs so u know , and pay attention to EXACT placement of EVERYTHING
i love my new sound system... Alpine type R 12" sub, Alpine deck, and MTX amp
2001 Z24 cavi, and it owns
Old 06-26-2005, 07:18 AM
public's Avatar
public public is offline
Re: changing rear drum brakes
TAKE A PICTURE-HA! just do one side of the car at a time. Use the other side as your reference. Also a Haynes manual can be handy, has photos plus hints on how to remove hold down springs, and even how to remove the drum(they can be tricky if they have a ridge worn inside).
Good Luck.
Yes, I am retarded.
Old 06-27-2005, 01:57 PM
or he could take a picture of it for reference and not have to get up and walk around the car everytime he gets confused
Old 06-30-2005, 04:13 PM
dennisinmo dennisinmo is offline
He is probably completed the job by now but I took the pictures. Then found that they were not the right angles to do me much good. If you take pictures, take several shots at several angles. The hubs can hide the springs you want to look at. The Haynes manual helped me a lot.
Old 09-29-2009, 03:19 PM
oneroundko's Avatar
oneroundko oneroundko is offline
Bump
Is the drum just essentially a free part once you get the lugs and rim off? Should it just come off, and if it doesn't and there is a lot of rust, is it rusted on?
I can't seem to get mine off; I have to change my rear brakes.
Old 09-29-2009, 03:24 PM
manicmechanix manicmechanix is offline
Originally Posted by oneroundko View Post
Bump
The drums are often times hard to get off. Sometimes you have to back off the adjusters because it's catching on the ring that has worn in. This will make it a lot easier to get the drums off.
Old 09-29-2009, 03:26 PM
oneroundko's Avatar
How do I do that?
Old 09-29-2009, 03:53 PM
There's a starwheel on the adjuster toward the bottom of the Drum. You have to access it from the blacking plate usually.
Old 09-29-2009, 04:02 PM
oneroundko's Avatar
Can I do significant damage if I continue to wack on it with a mallet trying to get it off?
