Old 06-25-2005, 01:21 PM
JailerX JailerX is offline
94 Cavalier AC Issue. Compressor?
Hi, Got a 94 Cavalier that when you turn the air on, it is cold for about 3-4 seconds then turns warm. If you turn it off, then on again it is cold for 3-4 seconds again. A guy at work said my compressor wasnt turning on. He tried the paper clip in the switch trick but there are 3 wires and didnt know which ones to do since some turned the check engine light on. Any suggestions? Thanks in advance for your time
Old 06-26-2005, 07:14 AM
public's Avatar
public public is offline
Re: 94 Cavalier AC Issue. Compressor?
If your compressor was not working it would not get cold at all. You are describing a system low on freon. Check for leaks, repair as needed, and refill. It is a 94 so it may just be low. You have some loss through the rubber hoses over time. Good Luck.
Yes, I am retarded.
