Go Back   Automotive Forums Car Chat > Hyundai > Excel
Old 06-25-2005, 11:39 AM
Joe678 Joe678 is offline
are the valves going to be bent?
1993 Hyundai Excel - bolt came out of the timing gear while running down the road. Since the timing belt came off, are the valves going to be bent? it has a 1.5L engine in it.thanks
Old 07-27-2005, 12:57 PM
frafreg frafreg is offline
Re: are the valves going to be bent?
I don't think so. My dad has a 1989 Excel with the 1.5L engine in it and the timing belt snapped on the highway. I replaced the belt and it still runs fine.
Old 07-29-2005, 02:33 AM
Goldenblade Goldenblade is offline
Send a message via AIM to Goldenblade Send a message via MSN to Goldenblade
Depends from case to case. Sometimes the timing belt wouldn't seem to do too much; other times, it would screw up your engine, especially the valves, terribly.
1990 Toyota Camry
Just under 225,000 miles.
Old 07-29-2005, 07:07 AM
If it is a non interference engine you will not damage your valves or pistons because the don't make contact. If the engine is an interference engine then yes, it can damage the valves and or pistons.
