Old 06-25-2005, 10:10 AM
96spyderman's Avatar
96spyderman 96spyderman is offline
Send a message via AIM to 96spyderman Send a message via MSN to 96spyderman
**Spark Plug INFO**
I did a quick search and found some quite useful spark plug info that I will share with all of you. I got all this info from NGK.
Spark plugs are one of the most misunderstood components of an engine. Numerous questions have surfaced over the years, leaving many people confused.
This guide was designed to assist the technician, hobbyist, or race mechanic in understanding, using, and troubleshooting spark plugs. The information contained in this guide applies to all types of internal combustion engines: two stroke engines, rotary engines, high performance/racing engines and street vehicles.
Spark plugs are the "window" into your engine (your only eyewitness to the combustion chamber), and can be used as a valuable diagnostic tool. Like a patient's thermometer, the spark plug displays symptoms and conditions of the engine's performance. The experienced tuner can analyze these symptoms to track down the root cause of many problems, or to determine air/fuel ratios.
SPARK PLUG BASICS:
The spark plug has two primary functions:
To ignite the air/fuel mixture
To remove heat from the combustion chamber
Spark plugs transmit electrical energy that turns fuel into working energy. A sufficient amount of voltage must be supplied by the ignition system to cause it to spark across the spark plug's gap. This is called "Electrical Performance."
The temperature of the spark plug's firing end must be kept low enough to prevent pre-ignition, but high enough to prevent fouling. This is called "Thermal Performance", and is determined by the heat range selected.
It is important to remember that spark plugs do not create heat, they can only remove heat. The spark plug works as a heat exchanger by pulling unwanted thermal energy away from the combustion chamber, and transferring the heat to the engine's cooling system. The heat range is defined as a plug's ability to dissipate heat.
The rate of heat transfer is determined by:
The insulator nose length
Gas volume around the insulator nose
The materials/construction of the center electrode and porcelain insulator
A spark plug's heat range has no relationship to the actual voltage transferred though the spark plug. Rather, the heat range is a measure of the spark plug's ability to remove heat from the combustion chamber. The heat range measurement is determined by several factors; the length of the ceramic center insulator nose and its' ability to absorb and transfer combustion heat, the material composition of the insulator and center electrode material.
The insulator nose length is the distance from the firing tip of the insulator to the point where insulator meets the metal shell. Since the insulator tip is the hottest part of the spark plug, the tip temperature is a primary factor in pre-ignition and fouling. Whether the spark plugs are fitted in a lawnmower, boat, or a race car, the spark plug tip temperature must remain between 500C-850°C. If the tip temperature is lower than 500°C, the insulator area surrounding the center electrode will not be hot enough to burn off carbon and combustion chamber deposits. These accumulated deposits can result in spark plug fouling leading to misfire. If the tip temperature is higher than 850°C the spark plug will overheat which may cause the ceramic around the center electrode to blister and the electrodes to melt. This may lead to pre-ignition/detonation and expensive engine damage. In identical spark plug types, the difference from one heat range to the next is the ability to remove approximately 70°C to 100°C from the combustion chamber. A projected style spark plug firing tip temperature is increased by 10°C to 20°C.
The firing end appearance also depends on the spark plug tip temperature. There are three basic diagnostic criteria for spark plugs: good, fouled and overheated. The borderline between the fouling and optimum operating regions (500&def;C) is called the spark plug self-cleaning temperature. The temperature at this point is where the accumulated carbon and combustion deposits are burned off.
Bearing in mind that the insulator nose length is a determining factor in the heat range of a spark plug, the longer the insulator nose, the less heat is absorbed, and the further the heat must travel into the cylinder head water journals. This means the plug has a higher internal temperature, and is said to be a hot plug. A hot spark plug maintains a higher internal operating temperature to burn off oil and carbon deposits, and has no relationship to spark quality or intensity.
Conversely, a cold spark plug has a shorter insulator nose and absorbs more combustion chamber heat. This heat travels a shorter distance, and allows the plug to operate at a lower internal temperature. A colder heat range is necessary when the engine is modified for performance, subjected to heavy loads, or is run at high rpms for a significant period of time. The colder type removes heat more quickly, and will reduce the chance of pre-ignition/detonation and melting or damage to the firing end. (Engine temperature can affect the spark plug's operating temperature, but not the spark plugs heat range).
Below is a list of some of the possible external influences on a spark plug's operating temperatures. The following symptoms or conditions may have an effect on the actual temperature of the spark plug. The spark plug cannot create these conditions, but it must be able to cope with the levels of heat...if not, the performance will suffer and engine damage can occur.
Air/Fuel Mixtures seriously affect engine performance and spark plug operating temperatures.
Rich air/fuel mixtures cause tip temperature to drop, causing fouling and poor driveability
Lean air/fuel mixtures cause plug tip and cylinder temperature to increase, resulting in pre-ignition, detonation, and possibly serious spark plug and engine damage
It is important to read spark plugs many times during the tuning process to achieve the optimum air/ fuel mixture
Higher Compression Ratios/Forced Induction will elevate spark plug tip and in-cylinder temperatures
Compression can be increased by performing any one of the following modifications:
a) reducing combustion chamber volume (i.e.: domed pistons, smaller chamber heads, mill ing heads, etc.)
b) adding forced induction (Nitrous, Turbocharging or Supercharging)
c) camshaft change
As compression increases, a colder heat range plug, higher fuel octane, and careful attention to igni-tion timing and air/fuel ratios are necessary. Failure to select a colder spark plug can lead to spark plug/engine damage
Advancing Ignition Timing
Advancing ignition timing by 10° causes tip temperature to increase by approx. 70°-100° C
Engine Speed and Load
Increases in firing-end temperature are proportional to engine speed and load. When traveling at a consistent high rate of speed, or carrying/pushing very heavy loads, a colder heat range spark plug should be installed
Ambient Air Temperature
As air temperature falls, air density/air volume becomes greater, resulting in leaner air/fuel mixtures.
This creates higher cylinder pressures/temperatures and causes an increase in the spark plug's tip temperature. So, fuel delivery should be increased.
As temperature increases, air density decreases, as does intake volume, and fuel delivery should be decreased
Humidity
As humidity increases, air intake volume decreases
Result is lower combustion pressures and temperatures, causing a decrease in the spark plug's tem-perature and a reduction in available power.
Air/fuel mixture should be leaner, depending upon ambient temperature.
Barometric Pressure/Altitude
Also affects the spark plug's tip temperature
The higher the altitude, the lower cylinder pressure becomes. As the cylinder temperature de-creases, so does the plug tip temperature
Many mechanics attempt to "chase" tuning by changing spark plug heat ranges
The real answer is to adjust jetting or air/fuel mixtures in an effort to put more air back into the engine
Types of Abnormal Combustion
Pre-ignition
Defined as: ignition of the air/fuel mixture before the pre-set ignition timing mark
Caused by hot spots in the combustion chamber...can be caused
(or amplified) by over advanced timing, too hot a spark plug, low octane fuel, lean air/fuel mixture, too high compression, or insufficient engine cooling
A change to a higher octane fuel, a colder plug, richer fuel mixture,
or lower compression may be in order
You may also need to retard ignition timing, and check vehicle's cooling system
Pre-ignition usually leads to detonation; pre-ignition an detonation are two separate events
Detonation
The spark plug's worst enemy! (Besides fouling)
Can break insulators or break off ground electrodes
Pre-ignition most often leads to detonation
Plug tip temperatures can spike to over 3000°F during the combustion process (in a racing engine)
Most frequently caused by hot spots in the combustion chamber.
Hot spots will allow the air/fuel mixture to pre-ignite. As the piston is being forced upward by mechanical action of the connecting rod, the pre-ignited explosion will try to force the piston downward. If the piston can't go up (because of the force of the premature explosion) and it can't go down (because of the upward mo-tion of the connecting rod), the piston will rattle from side to side. The resulting shock wave causes an audible pinging sound. This is detonation.
Most of the damage than an engine sustains when "detonating" is from excessive heat
The spark plug is damaged by both the elevated temperatures and the accompanying shock wave, or concussion
Misfires
A spark plug is said to have misfired when enough voltage has not been delivered to light off all fuel present in the combustion chamber at the proper moment of the power stroke (a few degrees before top dead center)
A spark plug can deliver a weak spark (or no spark at all) for a variety of reasons...defective coil, too much compression with incorrect
plug gap, dry fouled or wet fouled spark plugs, insufficient ignition timing, etc.
Slight misfires can cause a loss of performance for obvious reasons (if fuel is not lit, no energy is be-ing created)
Severe misfires will cause poor fuel economy, poor driveability, and can lead to engine damage
Fouling
Will occur when spark plug tip temperature is insufficient to burn off carbon, fuel, oil or other deposits
Will cause spark to leach to metal shell...no spark across plug gap will cause a misfire
Wet-fouled spark plugs must be changed...spark plugs will not fire
Dry-fouled spark plugs can sometimes be cleaned by bringing engine up to operating temperature
Before changing fouled spark plugs, be sure to eliminate root
cause of fouling
Q: When should I use a resistor spark plug?
A: NGK "R" or resistor spark plugs use a 5k ohm ceramic resistor in the spark plug to suppress ignition noise generated during sparking.
NGK strongly recommends using resistor spark plugs in any vehicle that uses on-board computer systems to monitor or control engine performance. This is because resistor spark plugs reduce electromagnetic interference with on-board electronics.
They are also recommended on any vehicle that has other on-board electronic systems such as engine-management computers, two-way radios, GPS systems, depth finders or whenever recommended by the manufacturer.
In fact, using a non-resistor plug in certain applications can actually cause the engine to suffer undesirable side effects such as an erratic idle, high-rpm misfire, engine run-on, power drop off at certain rpm levels and abnormal combustion.
Q: Are special plugs always necessary on a modified engine?
A: It depends on the modifications. The term "modified" refers to those engines that have received bolt-on improvements that may or may not raise the engine's total compression ratio. These can include turbocharging, supercharging, nitrous oxide injection, the use of smaller-chambered cylinder heads, modified piston configurations, free-flowing cylinder heads, change of induction components and/or the use of different fuel types and octane. These kinds of modifications generally require a change from stock spark plugs.
Modifications that will typically not require specialized plugs (in most cases the factory installed plug will be more than adequate) include adding a free-flowing air filter, headers, mufflers and rear-end gears. Basically, any modification that does not alter the overall compression ratio will not usually necessitate changing plug types or heat ranges. Such minor modifications will not significantly increase the amount of heat in the combustion chamber, hence, a plug change is probably not warranted.
However, when compression is raised, along with the added power comes added heat. Since spark plugs must remove heat and a modified engine makes more heat, the spark plug must remove more heat. A colder heat range spark plug must be selected and plug gaps should be adjusted smaller to ensure proper ignitability in this denser air/fuel mixture.
Typically, for every 75-100 hp you add, you should go one step colder on the spark plug's heat range. A hotter heat range is not usually recommended except when severe oil or fuel fouling is occurring.
Q: Does ignition timing affect a spark plug's temperature?
A: Yes, ignition timing directly affects the firing end temperature of the spark plug. Advancing the ignition timing prolongs the time to compress the burning gases. The pre-ignition temperature also elevates gradually, since the pressure and temperature of the combustible mixture is low before ignition. Advancing your timing elevates firing end temperatures.
Q: Do I need to set the "gap" when installing a new set of plugs?
A: Maybe. A spark plug part number might fit hundreds of engines and, although the factory will typically set the gap to a pre-selected setting, this may not be the right gap for your particular engine. Insufficient spark plug gap can cause pre-ignition, detonation and even engine damage. Too much gap can result in a higher rate of misfires, loss of power, plug fouling and poor fuel economy. It is always best to check the gap against the manufacturer's specifications.
Another consideration that should be taken into account is the extent of any modifications that you may have made to the engine. As an example, when you raise compression or add forced induction (a turbo system, nitrous or supercharger kit) you must reduce the gap (about .004" for every 50 hp you add). However, when you add a high power ignition system (such as those offered by MSD, Crane, Nology) you can open the gap from .002-.005".
There is more info at this link...
http://www.ngksparkplugs.com/techinf...200&country=US
This is the frequently asked question section where you will find some more tasty tidbits of info....
"A man's greatest work is to break his enemies, to drive them before him, to take from them all the things that have been theirs." -Ghengis Khan
Old 06-25-2005, 03:50 PM
JoeWagon's Avatar
JoeWagon JoeWagon is offline
Banned
Re: **Spark Plug INFO**
why not stop being a fuck head before i ban you?
Old 06-25-2005, 07:19 PM
Gsx_hooptie Gsx_hooptie is offline
Re: Re: **Spark Plug INFO**
Cool find, a lot of info, didn't know much of it.
96spyderman?
I used to own a DSM.
Originally Posted by Anon.
Capitalization is the difference between, "Helping your uncle Jack off a horse," and, "Helping your uncle jack off a horse." The comma is the difference between, "Eats shoots and leaves," and "Eats, shoots, and leaves."
Old 06-25-2005, 07:28 PM
joosdawg joosdawg is offline
Send a message via AIM to joosdawg
lol hooptie, i made some foul posts i guess... anyway awsome info im glad this came up time to get some new plugs for me
Old 06-25-2005, 07:37 PM
Hooptie, joosdawg was being a joker and joe warned him... lol... I had joosdawg delete what he posted... lol
Old 06-25-2005, 08:19 PM
l_eclipse_l's Avatar
l_eclipse_l l_eclipse_l is offline
Damn, that took a long time to read....
Good info, a lot of stuff I didn't know. WTF is going on with joosdawg or whoever the fuck that is....stop playin son, mods arn't gonna give you a hundred chances....
'92 3000gt SL
Zoom Stage 1 Clutch
Originally Posted by kjewer1
I disagree. Better is better. Bigger is just bigger.
I just made that up, and I like it.
Old 06-26-2005, 12:08 AM
trust me its all good it was marty and me messin around, no hard feelings to anyone were all friends you havent seen me around cause i rarley post unless i have a real problem i cant solve i just read alot... as you can see i joined in June 2003 but i only have 47 post's lol goodtimes
Old 06-26-2005, 02:53 AM
Killa_DSM's Avatar
Killa_DSM Killa_DSM is offline
Damn thats a lot of reading, but very good information.
"Life begins at 20psi"
97 Eclipse GST-X 5spd
PTE 5031e/pte 880cc/vr4 fuel pump/Devils Own Water injection 12gph nozzle/pre turbo meth injection/fmic 28x10.5x3.5/greddy type-s bov/12" K&N/FP intake/dsmlink/gm 3.3 bar/maft/blitz ebc/act 2600/act 6 puck/SS Clutch line/3" turboback.
Old 07-02-2005, 12:15 AM
BoostedSpyder's Avatar
BoostedSpyder BoostedSpyder is offline
Send a message via MSN to BoostedSpyder Send a message via Yahoo to BoostedSpyder
i just changed my plugs after about 10k miles.
#3 was toast. not hot enough to burn anything. i was also getting a random misfire CEL [per pocketlogger] that was intermitent.
they were also all around .038 and if you were wondering, they all went in at .028
so check your plugs and stuff.
check the latest mixes!!!
http://waxdj.com/djs/675/
