Old 06-25-2005, 07:46 AM
AnneJac AnneJac is offline
Angry Stupid MAF sensor!
I just replaced my MAF sensor because the OBDII said that was the problem. It was stalling at idle and running real rough. The problem now is that it won't run at all!
After I replaced the sensor, I started the engin and it ran okay for a few minutes. I put it in gear to drive it back into the garage, and it stalled. Now it wont even run. It will start, but sputters, pops, and stalls.
Any ideas?
I also noticed a hose (to what I have NO CLUE) that has melted a little. Might that be the problem?
I can explain more if anyone has any ideas.
It a 2000 ZX2 with about 75K miles...
Old 06-25-2005, 08:00 AM
Cobra_Sam Cobra_Sam is offline
Re: Stupid MAF sensor!
Any ideas?
First, it is always helpfull for experts out there to help you faster if you give all the specifications of the vehicle. Make ,year, model and engine size, mileage and so on. From the little info you gave I would recommend you replace the melted hose, which seems like an important vacuum hose and then if the problem still occures, run the test. Depending on the year could mean a lot, newer cars have a lot of sensors.
Good luck
Sam
Old 06-25-2005, 08:06 AM
Re: Re: Stupid MAF sensor!
2000 ZX2 75K miles (sorry- new to this)
Old 06-25-2005, 12:49 PM
riccbhard riccbhard is offline
I'm confused. Is there actually a sensor called the MAF sensor? I know there's a MAP sensor
MAP: http://en.wikipedia.org/wiki/Manifold_Absolute_Pressure
Old 06-25-2005, 11:49 PM
Mass Air Flow sensor .... sits inside the air intake.
Old 06-27-2005, 04:11 PM
jeffescortlx jeffescortlx is offline
Send a message via AIM to jeffescortlx
Give the MAF wire harness a tug to make sure it's plugged in all the way. With the way the air box is set up it's real easy to not "snap" the plug in all the way. Make sure the wire rubber gromet is in place. Check for vac leaks in all the hoses and tubing.
Can you get us a pic of this melted hose?
I make slow Escorts less-slow.
My cardomain
Old 07-10-2005, 05:51 AM
AzTumbleweed's Avatar
AzTumbleweed AzTumbleweed is offline
May be wrong but I think MAP and MAF are the same thing. If you have a vacuum leak caused by the melted hose then this could cause the false code. But then again, it's doing it's job-telling you that the vacuum is out of the proper parameters.
