Old 06-24-2005, 10:27 PM
gottabike gottabike is offline
Send a message via MSN to gottabike Send a message via Yahoo to gottabike
radiator replacement w/ oil cooler
OK, folks it finally bit the dust. my radiator blew on me this morning on my way to work. I have the oil cooler and need to replace the radiator. Now my question is that oil cooler, is it pumping antifreeze through it or something else? i dont wanna pull it out and release something i shouldnt. I'm hopin its just anti-freeze as well. Please let me know folks. I gotta get my car back.
Old 06-24-2005, 11:04 PM
HotZ28's Avatar
HotZ28 HotZ28 is offline
AF Moderator Elite
Re: radiator replacement w/ oil cooler
Don't worry, the oil cooler only circulates coolant from the radiator.
Old 06-25-2005, 08:06 PM
OK, cool deal. That means it will take me about a hour to fix if i'm lazy about it.
Old 06-25-2005, 09:54 PM
Flatrater's Avatar
Flatrater Flatrater is offline
Main GM Guy
If your oil cooler pumped antifreeze thru it it would be called a radiator not an oil cooler. I would guess an oil cooler has oil going thru it.
Shop Foreman Buick Pontiac and GMC dealership
ASE Master Tech
ASE Advanced L1
GM Master tech
Licensed Aviation mechanic
Old 06-26-2005, 09:21 AM
deadring deadring is offline
theres an oil cooler on a pa?? where? i have a BIG one for the oil tranny which i know is not standard. but i havent seen an engine oil cooler on my 92 ultra
Deadring
89' corolla ...200 000 miles on original engine, tranny,clutch and paint...and no rust... try that with a neon...
00' kawasaki zx-9 with micron exaust and K&N filter ( my baby)
Old 06-26-2005, 10:18 PM
HotZ28's Avatar
AF Moderator Elite
OK, let's be sure what you are talking about. Is it the trans cooler or does the radiator have coolant lines going to an area where the oil filter is mounted?
Old 07-03-2005, 03:25 PM
yes its a trans oil cooler. there is transmission fluid in there. I know now because when i disconnected it, the old hose got cut by the clamp. I'm now leaking trans fluid from it. I know because its slipping up hills. So i will more than like be getting the new hose and hopeing that i can finally get this damn thing taken care of. As for the radiator we used a whole set of JB weld and it went from a pour to a drip. Dont buy that stupid wanna be putty go with the real deal stuff if you have the problem i had.
Old 07-04-2005, 12:49 AM
HotZ28's Avatar
AF Moderator Elite
Good news, I also have not seen a engine oil cooler on the PA's however I do have them on both of my Z28's. If you order the Chevorlet with the police option package, they come with a oil cooler that circulates coolant from the radiator to a housing that the oil filter mounts to. Of course, they don't mix and I assume they do help cool the engine oil somewhat.
