Go Back   Automotive Forums Car Chat > Ford > Probe
Old 06-24-2005, 09:04 PM
JimR's Avatar
JimR JimR is offline
engine
What type of engine is in the GTs? i know its a 24valve DOHC but what brand/type.
Example my SVT Contour Has a 2.5L 24valve DOHC Duratec.
and my Escape has a 3.0L duratec.
Old 06-27-2005, 02:56 PM
lowered96probe lowered96probe is offline
Actually the ford probe motors were built by mazda, THese were special built motors no other motors are the same. The motor changed very little for the years.
Old 06-27-2005, 09:19 PM
JimR's Avatar
Re: engine
ya i know that the engine is a mazda, the car is based off of o is the based of the mazda MX-6 MX-3 626 ect., that is why is is as durable as it is. but what is the name of the engine. i can get more dont if i know what it is. i am not spending $ one a Kize engine to go from about a 9:1 compression to a 10:1 compression.
Old 06-28-2005, 10:33 AM
sickandtwisted sickandtwisted is offline
Re: engine
do you know if its possible to drop a klze in to the base or se
97 probe base
gt tail light and bumber cover
plazma glow neon
apc fogs
sensei kit at paint
new wheels and tires comming soon
as well as av sys
and web page comming next few weeks
Old 07-01-2005, 01:29 AM
performanceprobe's Avatar
performanceprobe performanceprobe is offline
Send a message via MSN to performanceprobe
Cool Re: engine
it is most likely the 2.5L 24 valve DOHC KL03
Old 07-13-2005, 12:21 AM
VlaDeMaN VlaDeMaN is offline
Re: engine
it is definitely worth it go for a klze. you wouldnt just gain more compression, but you would go to 200hp stock with the jdm ecu. remeber that any mods you do will also give you more power than the stock 2.5l.
and yeah you can absolutely the 2.5l v6 into a base probe. you will also need a gt tranny. you can even use the base axles. some turboed 4 bangers make over 220hp on stock BASE axles. 200hp on base axles is safe.
its is the kl03 indeed.
Old 07-13-2005, 09:08 AM
JimR's Avatar
Re: engine
so KLO3 is the name given to the stock GT engine?
Old 07-13-2005, 12:56 PM
Re: engine
stock US yeah. europe too.
the KL block had the aid of porsche as far as engineering goes. also from what i've heard around, mazda had built a ton of engine blocks to use in F1, but they decided to go a different way...so they got stuck with a bunch of blocks lying around, and so they decided to build a production car around them...isnt that cool, our engines were gonna be F1 monsters...
Old 07-14-2005, 10:42 AM
JimR's Avatar
Re: engine
realy? so these engines where going to be HO's for F1's?
Old 07-15-2005, 01:15 PM
Re: engine
thats what i hear, sweet huh? also the klze has more agressive cams, a better flowing intake manifold and heads, and a better ECU. get a ZE man...
Old 07-15-2005, 06:06 PM
JimR's Avatar
Re: engine
how much do they cost???
Old 07-15-2005, 07:14 PM
Re: engine
about 900 bux...you're talking about the engine, right?
Old 07-18-2005, 02:16 PM
JimR's Avatar
Re: engine
ya what web site can i get them from?
