Old 06-24-2005, 08:37 PM
metallica21156's Avatar
metallica21156 metallica21156 is offline
flowmasters? hard on cats?
are flowmasters hard on cats? i put one one and its been on for about 6 months and i think the cat may be falling apart. when istart it up and i hit the gas you can here a slight rattle. i can hear its something inside and not out. its the orginal cat. is it age or the muffler?
95 jimmy. Vortec V6. 4.3 liter CPI. ,2.5" catco cat, 2.5" cat back with flowmaster muffler split rear., 40 street series, 2 12" audiobahns in custom box,K&N CPI intake system.
71 Mustang coupe- project car. stock 302 with Cobra intake, holley 650dp, afco racing radiator, headman headers, msd distributor, 2.5" from the headers.C4 tranny with shift kit, Mach 1 body lay out.
90 cav, 2.2 tbi, gas getter.
99 chevy s10 zr2, 6" lift, duel exhaust. 5 speed.
Old 06-24-2005, 11:42 PM
Tangent Tangent is offline
Re: flowmasters? hard on cats?
Age. I've never heard of a muffler causing a cat to fail. Unless of course you ran over a Flowmaster on the freeway and it smacked the cat...
Old 06-25-2005, 12:12 AM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
What you might be seeing is normal cat failure.
Especially if you ever had a bad CPI pouring fuel into it some time in its past.
1995 Factory Blazer Service Manual for sale, PM if interested.
Old 06-25-2005, 09:22 PM
how much louder do u think it would be if i pulled the cat off and put a pipe in instead of another cat? i know it wouldn't pass emissions but i got 2 years until then.
Old 06-26-2005, 01:41 AM
BlazerLT's Avatar
AF -Advisor
It will get louder, but no by much.
It will also sound a lot more raspier.
Old 06-26-2005, 11:54 PM
If you've got OBD2 you'll get a check engine light if you remove the cat. 95 is a borderline year for the OBD1 -> OBD2 switch and I'm not that familiar with when the Blazer might have switched. If it is OBD2 there's an O2 sensor before and after the cat to determine if the cat is working properly.
Old 06-27-2005, 01:13 AM
BlazerLT's Avatar
AF -Advisor
95 jimmy has an O2 sensor before and after the cat.
Don't remove the cat if you have one after the cat because it will throw a code.
You can get a high flow 2.25" cat on ebay for cheap and have it installed.
Old 06-27-2005, 01:17 AM
s10blazerman4x4's Avatar
s10blazerman4x4 s10blazerman4x4 is offline
Send a message via AIM to s10blazerman4x4
check out the seller Performance Curve he has alot of different stuff.http://stores.ebay.com/Performance-C...QQftidZ2QQtZkm
1991 Chevy S-10 Blazer 5.7 V8 RIP
1999 Chevy Blazer 2dr 4.3
Old 06-27-2005, 02:17 AM
BlazerLT's Avatar
AF -Advisor
This will help too.
http://search-desc.ebay.com/2-1-4_Ca...fsopZ1QQfsooZ1
