Old 06-24-2005, 05:50 PM
AngelBaby2000 AngelBaby2000 is offline
Knocking Problem
i've got a 95 elagle talon tsi with turbo. we just set the timing for the crank & the cams, and now the engine will not stay running. it idles REALLY rough & dies when u take uu'r foot off the gas. also, seems to back fires on piston two
Old 06-24-2005, 07:20 PM
JoeWagon's Avatar
JoeWagon JoeWagon is offline
Banned
Re: Knocking Problem
So the first question is, did you make sure the timing is actually correct?
Old 06-24-2005, 08:43 PM
drewh4386's Avatar
drewh4386 drewh4386 is offline
Send a message via AIM to drewh4386 Send a message via MSN to drewh4386 Send a message via Yahoo to drewh4386
yep because that is usually the syptoms of incorrect timing.
....It has been a LONG time...I want to move to FL or Japan.....
Old 06-25-2005, 10:38 AM
the timing is right but someone told me that all i had to do was unplug the timing plug & plug it back in. my question is, where is the timing plug?
Old 06-25-2005, 01:36 PM
tfoti tfoti is offline
Testiklees
Send a message via AIM to tfoti Send a message via MSN to tfoti
I don't know about any "timing plug"??? You need to re check the timing marks and make sure they are dead on. Especially pay attention to the cam sprockets as they are really easily mistaken for being correct when they are in fact half a tooth off. If the car ran fine before the timing belt change and all you did was the timing belt, then you're timing marks are off.
Follow the steps at www.vfaq.com to verify you did it right, or whoever did it.
Tim
1990 Talon AWD
2.3 stroker, 8.8 wiseco, FIC 750's, DSMLink,
PTE SCM5031
Old 06-25-2005, 02:01 PM
drewh4386's Avatar
are you sure the timming is right? It being off a few degrees can hurt in some way.
Old 06-26-2005, 01:38 AM
kjewer1 kjewer1 is offline
AF - Advisor
Re: Re: Knocking Problem
I'm assuming you are talking about the diagnostic plug that you can ground to hold ignition timing to 5 degrees so you can set it accurately, only found on 95s, brown, behind the battery/cruise control on the firewall harness section. It has nothing to do with valve timing specifically, but any change to intake cam timing can affect ignition timing (perhaps not on 2Gs with stock sensors).
If this happened only after changing cam timing, and you are absolutely certain the timing is correct, I would start to look for things not plugged in during reassembly. Any check engine lights?
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
