Old 06-24-2005, 05:15 PM
whiteypa whiteypa is offline
my gt automatic only has 3 rd gear and reverse,
i put a water pump and a timing belt on the car and when i went to drive it after that it only had 3 rd gear and reverse, can anyone help me?
Old 06-24-2005, 05:26 PM
Linebckr49's Avatar
Linebckr49 Linebckr49 is offline
Send a message via AIM to Linebckr49
Re: my gt automatic only has 3 rd gear and reverse,
crap, i know what you have is common with Autos and it is easily fixed. several ppl here have had this problem. however i can't remember any specifics. Hotshot8972 can answer your question.
93 3000GT base
K&N | long tube headers | 3sx crank pulley| testpipe | Addco front/rear sway bars (3SX) | rear strut bar & front 3-point strut bar (by JonVr4 on 3Si) | solid motor mounts | LSD insert | KYB GR-2 struts | intrax springs | adj. control arms | ss brake lines | 16% taller 5th gear (teamrip.com) | H4 conversion | push-button start | datalogger | HKS S-AFR | PLX WB O2
coming soon: adj. cam gears | bi-xenon HID retrofit
