Go Back   Automotive Forums Car Chat > Chevrolet > Avalanche | C&K | Silverado | Suburban | Tahoe > Suburban
Old 06-24-2005, 04:11 PM
mac10334 mac10334 is offline
95 Suburban power lock problems
hello I have a 1995 suburban and the power locks stopped working and all i hear is a slight clicking. I pulled the fuse out witch was extremely hot and let it cool down and put it back in, then they started working again.
what would cause this ??
any help is appreciated.
Old 06-30-2005, 12:01 PM
mikeinut mikeinut is offline
Re: 95 Suburban power lock problems
My 99 burb did the exact same thing. Sometimes one or two would work and then the next day none of them would work. I replaced the relay that just clicked when I pushed the lock switch and it did the same thing. I found some actuators on Ebay and replaced all four doors plus the cargo door. They work perfectly now. Just a note, if you have cargo doors, the actuator for the rear cargo is the same as the other 4 doors. There's some good info on here about replacing the door lock acutators. It took me maybe an hour total to do all 5 doors. (I was already familiar with how to take the door panels off) Good luck.
Old 11-09-2005, 09:01 AM
fromcgee fromcgee is offline
door lock problem
im having the same doorlock problem and wanted to know if anyone has ever solved it all my doors work ok but the relay get super hot and they will not work any more but if i let the relay cool down they will all work until the relay heats up again which takes less that 1min.
