Go Back   Automotive Forums Car Chat > Mercury > Grand Marquis
Old 06-24-2005, 03:32 PM
kike058 kike058 is offline
Banned
Send a message via Yahoo to kike058
Runs Like in 7 Cilinders
I have this 1994 grand marquis with 4.6 L engine. About a Week ago felt a drop o power, like a lost of a spark plug.
This weekend I chenged the fuel filter, sprak plugs and I still had the problem. When a was checking the spark plugs again I noticed that the Spark on the Coil Pack on the driver side, the 2 conector for the No. 2 and No. 8 cilinder was not as vivid as the other 2.
So Yesterday I changed the Coil Pack for a new one with the same results.
After re-checking all the cilinders, I felt like the No.2 cilinder is the one that seems to be the one with lack of power.
After that I swap the No. 2 and No. 3 injectors and plugs just to make sure thay are OK, then cheked the compresion on all cilinders and they are around 150 PSI.
At the end of the day and all this work done, I still have the same problem.
I have one word for you guys.
H E L P !!!!!!!!!!!!!!!!!!!!!
Thanks
Old 07-01-2005, 07:31 AM
fredjacksonsan's Avatar
fredjacksonsan fredjacksonsan is offline
Caution: Monkeys bite!
Send a message via AIM to fredjacksonsan
Re: Runs Like in 7 Cilinders
Sounds like it's not getting the voltage to fire the plug. How are your spark plug wires?
Ours: 2020 Jeep Wrangler 2.0, 53k
2013 Toyota FJ Cruiser, 84k
Kids: 2005 Honda CRV, 228k
Old 07-01-2005, 11:48 AM
Banned
Re: Re: Runs Like in 7 Cilinders
Fred:
Thanks for reply.
I changed the wire for new ones made by Bosch.
Problem solved.
My previous owner have it isntall some p.o.s. wires.
I Still need to check the EGR valve.
Thanks again
Old 07-01-2005, 12:32 PM
Old 07-01-2005, 12:40 PM
jimmytroanoke jimmytroanoke is offline
If you have any more problems get Motorcraft wires. If you did not put dielectric grease in the boots take them loose and do it now. When it rains water can pool in the plug wells and that is why you need the grease. Also makes it easier to get them off when it is time to change plugs
2001 Grand Prix SE 3.1 - Someone elses problem now!
95 Grand Marquis - Will outlive all of them!
97 F-150
2004 Toyota Avalon
Old 07-01-2005, 01:39 PM
cobradude360's Avatar
cobradude360 cobradude360 is offline
Send a message via AIM to cobradude360
whats wrong with your egr?
THE 92 grand marquis LS M75 with the 281 romeo v8 u cant mess with that
MODS: dynomax bullit exhaust, custom intake, polished upper plenum, 180T-stat, accel coil packs and platnum plugs
also 2005 crysler sebring sedan walter p crysler edition yea its got the 2.4 pics comin soon
Old 07-05-2005, 11:41 AM
Banned
The check engine goes on, I have this code tester and it shows this code for "No EGR flow present".
I need to take off to check if it's stuck or something.
Some time the engine knocks under acceleration, and then the light goes on.
I'm using 86 fuel and the temp is normal, so I think that the EGR is not opening when it should.
Old 07-05-2005, 12:23 PM
This engine is famous for clogged EGR Passages in the intake. Remove the elbow that your throttle body is attached to from the intake and look under the gasket - there is a horseshoe shaped passage there that is full of guck. shopvac the guck out and push a rod down the passages to the egr valve. this is so common on these engines that the EGR valve itself is rarely the culprit.
97 F-150
2004 Toyota Avalon
Old 07-05-2005, 12:28 PM
try useing a tiny flat bladed screw driver also to clean them out i did this and noticed a really big differnce in idle and a lil performance also try some carb and choke cleaner if it gets hard to remove also order a new gasket for were the elbow meets the manifold
Old 07-11-2005, 03:47 PM
jesus058 jesus058 is offline
Send a message via Yahoo to jesus058
Thanks for the hint guys.
Finally I had the chance to dive into de elbow and I did what you told me, you were right, that horse shoe shape pipe was clogged. Looks like the problem is gone.
The odd thing here is that the I saw no gasket on the elbow - manifold joint and it's running fine.
Old 07-11-2005, 06:57 PM
Are you sure that the gasket was not stuck to the elbow? If not, then you better get one from the dealer - they are only 3 bucks and most dealers stock them because this problem is so common. Otherwise you are headed for a vacuum leak which will cause all kinds of driveability concerns and false check engine lights.
97 F-150
2004 Toyota Avalon
Old 07-11-2005, 07:43 PM
if its the horse shoe linr i think ur talking about then its the line to the idle air control moter
Old 07-12-2005, 12:14 PM
Noup, It's actually the passage that is under the throttle elbow.
Thanks for the hint again.
Old 07-12-2005, 12:26 PM
Re: Re: Re: Runs Like in 7 Cilinders
At this time the car is running OK, no check engine light so far.
I clean both surfaces very well before re-installation.
Anyhow, at the first chance I will install that gasket.
Thanks again
Old 07-26-2005, 11:15 PM
full_flex full_flex is offline
Hi, I think I'm having the same problem. Can someone explain where and what I'm supposed to be replacing/cleaning? Any detail or information on how to proceed would be very appreciated. Thanks in advance.
