Go Back   Automotive Forums Car Chat > Dodge > Ram Van
Old 06-24-2005, 02:13 PM
IslandLady's Avatar
IslandLady IslandLady is offline
Send a message via ICQ to IslandLady Send a message via AIM to IslandLady
Unhappy Electrical Problem? Need Help, PLEASE
'86 RAM250 van, slant six (225) This Island Lady is in deep Kim Chee.
I was heading into town (Kailua-Kona) when my left blinker light came on ... not blinking, but on solid. The blinker lever didn't work. I then saw that my gas gauge had dropped to zero (I just filled it before I left), my heat gauge was clear to the top, the oil gauge was clear to the top. I pulled over and my rear brakes were locked up and rolling smoke. I turned off the key, and the engine kept running. It finally shut off about two minutes later.
I popped the hood and checked the radiator first ... it was not overheated. Sat there for a few minutes trying to figure it out ... short in the steering column? In the dash? Why would the rear brake lock? Isn't that totally mechanical? Would it be a separate issue and just coincidence?
After sitting for 5 minutes or so I tried the key and it started right up. Drove home slowly while the instrument panel went from normal reading to crazy ones and back again. When I started up the mountain it began to run rough and lose power. Just barely made it home. I could feel the rear brake locking and releasing several times.
Now I'm stuck on the mountain; I have tools, but know next to nothing about electrical. Anyone got any advice? Please?? HEEEELLLPPPPP!!
IslandLady
Old 06-25-2005, 10:49 AM
frankendart frankendart is offline
Send a message via AIM to frankendart Send a message via Yahoo to frankendart
Re: Electrical Problem? Need Help, PLEASE
I'd Check the Ground lead going to the engine block first. I experienced a similar problem, and that's what I found to be the cause.
Thanks,
Frank
SUCK-SQUEEZE-BANG-BLOW!!!!
It's just how things work!
I own 4 Fords, 3 Chevies, 3 Saturns, 2 GMC's, and 2 Dodges... So tell me about your brand loyalty.
Old 06-27-2005, 10:13 AM
fredjacksonsan's Avatar
fredjacksonsan fredjacksonsan is offline
Caution: Monkeys bite!
Send a message via AIM to fredjacksonsan
Also, I've had of weird problems with a corroded positive side battery cable. Worth checking that out; I've had two vehicles that did very strange things until I replaced the positive cable.
Ours: 2020 Jeep Wrangler 2.0, 53k
2013 Toyota FJ Cruiser, 84k
Kids: 2005 Honda CRV, 228k
Old 06-30-2005, 02:14 AM
IslandLady's Avatar
Mahalo
Thank you for the input gentlemen ... I'm pursuing the possibilities, even though I have still utterly failed to find the apparently-mythical "grounding strap" supposed to ground the block to the frame/firewall. I'll be hitchhiking 40-odd miles down to the coast this weekend for a new strap and new battery cables. (Ick)
IslandLady
Old 06-30-2005, 06:50 AM
Good luck; I'd offer a ride but I'm on the east coast.
