Old 06-24-2005, 01:58 PM
Mannyb18b's Avatar
Mannyb18b Mannyb18b is offline
Send a message via AIM to Mannyb18b Send a message via MSN to Mannyb18b
started a fire!
Alright, so i come across a free PG XS-2300, so i decide i'll hook those up to my 6x9's for now. Hooked them up, sounded great. I currently have no subs in my car, an had no extras lyin around. A friend gave me a Sony p5 (i know) for free, so i took it, threw it in a sealed 1ft enclosure an hooked it up to a PA amp givin it close to 500watts. everything was coo for a bit, then i was movin stuff around cause i was changing the position of the box, on the PG amp the POWER and GROUND are right next to each other (who thought of this i dont know!), well while i was movin stuff they touched an sparked which i knew was no good, but before i could run an get a screwdriver to unhook the power wire it caught on fire. my ground wire bursted into flames an took the remote wire with it. then smoke started pouring out of the PG amp, an then out of my PA amp????? havnt found out if they work anymore, but it was alot of smoke
300amp excessive amperage
Alpine H/U-
Incriminator Audio 20.1 @.35
(2) 15" Q's 8 cubes after 80sqin. 28hz
CDT EF-61's
Profile AP1040 on comps
NSB-100
Old 06-24-2005, 02:50 PM
PaulD PaulD is offline
Audio Guy
Send a message via AIM to PaulD Send a message via Yahoo to PaulD
ummmm .... that's we fuse close to the battery - only thing that woulda happened is a blown fuse (a couple doolars at most) or popped circuit breaker
Old 06-24-2005, 03:20 PM
CBFryman's Avatar
CBFryman CBFryman is offline
Banned
Send a message via AIM to CBFryman Send a message via Yahoo to CBFryman
Re: started a fire!
doolars, lmao
always fuse for daily apps. be glas you didnt grab the wires to try and pull them apart or that you didnt set your car on fire.
Old 06-24-2005, 04:07 PM
ToyTundra's Avatar
ToyTundra ToyTundra is offline
Re: started a fire!
if all you lost was an amp or two I consider you lucky
Old 06-24-2005, 08:28 PM
ngsm13's Avatar
ngsm13 ngsm13 is offline
Send a message via AIM to ngsm13
Re: started a fire!
Yup, fuse your wires dummy...
NG
I design custom enclosures!
And...my sig is short!
Oh and.. YOU suck balls...
Old 06-24-2005, 09:09 PM
L|_|da L|_|da is offline
Send a message via AIM to L|_|da
Re: started a fire!
wow no fuse....
Old 06-26-2005, 03:48 AM
RickwithaTbird's Avatar
RickwithaTbird RickwithaTbird is offline
Send a message via AIM to RickwithaTbird Send a message via MSN to RickwithaTbird Send a message via Yahoo to RickwithaTbird
Re: started a fire!
make better connections next time too.
R.I.P.: My Thunderbird "Ricks 96".. 2/08/96 - 1/14/05.
Old 06-27-2005, 12:48 AM
Mannyb18b's Avatar
Re: started a fire!
It is fused......DUMMY
Alpine H/U-
CDT EF-61's
NSB-100
Old 06-27-2005, 07:18 AM
sr20de4evr's Avatar
sr20de4evr sr20de4evr is offline
what size is the power wire and what size and type is the fuse
'01 Black Sentra SE
Weapon-R intake, HS header, HKS catback, ES motor mounts, B&M short shifter, Tein coilovers
Alpine 9835, Adire Koda 6.1, Adire Brahma 15, Arc 2100cxl, Linear Power 2.2hv, Cadence ZRS-8
'05 Silver WRX STi
Injen SES Downpipe, HKS Carbon-Ti catback, Cobb Stage 2 Tune, TiC Super Shifter, TiC Klunk Killer, Tein springs, Nitto NT555R Drag Radials
Old 07-02-2005, 09:53 PM
PBking82 PBking82 is offline
Re: started a fire!
If it was fused CORRECTLY that would have never have happened. When I was moving around my sub box(amp is mounted on the box iknow iknow!!) the power wire shook loose and touched the grounding point. All it did was spark and go POP! and the fuse went. Peace-
