Old 06-24-2005, 01:46 PM
Link85x Link85x is offline
Talking 305 Power Parts
Alright, geared for 89 to respond, but any input will do.
Are these the vortec heads with the 062 casting
http://www.jegs.com/cgi-bin/ncommerc...83&prmenbr=361
if not what about these world products heads
http://www.jegs.com/cgi-bin/ncommerc...41&prmenbr=361
Ok with one of these heads would this stroker kit work with them
http://shop.enginekits.com/osb.itemdetails.cfm?ID=341
if the kit works out, what cam should i get along with these parts?
What else am i missing? Better injectors (what type), throttle body (what type), can anyone tell me everything that i would need to complete this project the right way? I'm gonna start buying everything now and until i start the project, which is gonna be during the winter, and i'm gonna be pretty much getting all of my help from you guys on here so you can take credit when ever it finished. I'm willing to put the money into the motor, and i absolutely love the 305, that hunk of boat anchoring iron. Come guys and help me out here.
87 IROC - R.I.P, and she will never be forgotten
90 RS - The beginning of a new era... I hope.
Old 06-24-2005, 02:29 PM
LT1MAN LT1MAN is offline
Banned
Re: 305 Power Parts
still waiting on 89..............
Old 06-24-2005, 04:12 PM
wrightz28's Avatar
wrightz28 wrightz28 is offline
is bring'n sexy back
Re: 305 Power Parts
Well, I'll chime in with some basics.
Starting with the platform, the subframe, is it worth it and can handle the upgraded stress?
The cam and intake side is all going to depend on your compression ratio the stroker kit and cylinder heads will alter you to. You are talking allot of blueprinting here and crunching numbers. I also do believe you have to overbore the center intake manifold mount bolt holes in order to seal up the vortec heads.
Sorry man, you just can't throw a laundry list of parts under the hood and come out roaring, I wish it were that easy but it's not. Sometimes you can, but then you may not reap the fulll power of the combo, or sometimes you can't, and say throw a cam with too much lift in it and whammo.
Anyways, the guys at jegs and summit, I'm sure could get you started in the direction you're looking to go, accurately, and then the finishing parts could be recommended,
Or, and ultimately better in my eyes, to save you all the grief of the aforementioned. A master rebuild/stroker kit (I even think World offers one up?) that has everthing already figured out. Aside from fuel deivery and air intake cfm requirements.
Oh, and probably be cheaper too since you'll have all your gaskets and misc. parts.
Whatever became of your TES headers? Get em in yet?
Old 06-24-2005, 06:52 PM
bag91's Avatar
bag91 bag91 is offline
Re: 305 Power Parts
[quote=Link85x] and i absolutely love the 305,
Thats how its done, finally someone who appreciates the 305.
91 RS Camaro V8 305 TBI
cold/ram 14"/3" open element
K/N filter
3.73's
B&M Megashifter
180 thermostat
Flowtech TERMINATOR Exhaust
3" exhaust cutout
Silvania Silverstar Headlights
Ronal R15 Firehawk Wheels
Hankook Ventus Sport (front)
Sumitomo HTR+ (rear)
275/40ZR 17 all around...
_____________________________
Old 06-25-2005, 12:44 AM
drvngstorm05's Avatar
drvngstorm05 drvngstorm05 is offline
u keep lookin at cast iron heads, i say lower ur heat and weight by gettin some alluminum heads... found some gm performance parts fast burn heads for ur application on summit (i prefer summit to jegs...) part number: NAL-12464298. along w/ that get some 1.6 ratio roller rockers like these: CRN-10758-16 or SUM-G6936-16. lower intake manifold and runners: EDL-3890. and u can get that cam i offered ya (check ur PM)
there really is no limit to what all u can upgrade... i just showed u a couple of things that i might go with if i were in you're shoes. i would recommend u look at accel for injectors (maybe 30lbs) and get a 52mm throttle body. also go to pcmforless.com to get it all tuned.
all i can say is do ur research, spend wisely and ask questions, like u are now. call and talk to the guys at summit they are a big help. see if u can find some other guys that have done some stuff to thier 305, and see how things turned out for them. don't take it too fast
'92 RS lt1/t56, lt4 hot cam, 30lb injectors, 54mm throttle body, full exhaust, 4.11 posi, 4 coil ignition, alluminum driveshaft, adj rear suspension, low. springs, electric water pump, custom tune.
Old 06-25-2005, 02:08 AM
charlie0915 charlie0915 is offline
Send a message via Yahoo to charlie0915
Re: 305 Power Parts
hi guys i bought an 89 camaro rs with only 517 miles on it origanal i was wondering if you could tell me what i can do to upgrade my engine and give it more power
Old 06-25-2005, 02:33 AM
Re: Re: 305 Power Parts
i'm assuming u have a 305tbi right? anyway check the performance subforum they have put alot of stuff there about 305tbi performance parts and upgrades
Old 06-25-2005, 07:41 PM
89IROC&RS's Avatar
89IROC&RS 89IROC&RS is offline
Re: 305 Power Parts
Those heads are better than the 062 castings. When i say 062 casting i am referring to the production castings. The cylender heads have part numbers cast into the rocker vally. There are two versions that were in production, one ended in 062 the other ends in 908, the 062 castings are the desireable ones. The ones you are looking at from jegs have much larger ports and will flow more air. However a 305 does not have high air demands so you might be better off with a 170cc port vortec head design.
as far as all the ins and outs, weve been having alot of engine building questions lateley, so im going to do a very in depth post later tonight covering the basics. and then a second covering the more advanced stuff.
Chevrolet Camaro - I enjoy beating the hell out of people
http://www.automotiveforums.com/vbulletin/showthread.php?t=68052
Old 06-25-2005, 10:05 PM
1986Z28's Avatar
1986Z28 1986Z28 is offline
Has a Camaro
Send a message via MSN to 1986Z28
holley makes a nice tb
Formerly Blownalcoholboy
1986 Z28, 400ci SBC, Twin borg warner billet S467 turbos, Reid case powerglide, Moser 9". Holley EFI, Boost Leash. 950RWHP on pump gas, 1200rwhp on race gas (22 psi)
Best ET 1/4: 8.35 @ 170mph (275 drag radial)
Best ET 1/8: 5.44 @ 132mph (275 drag radial)
Best 60': 1.31 on the back tires (275 drag radial)
AF User Rules/Guidelines
http://www.automotiveforums.com/vbul...uidelines.html
Old 06-27-2005, 07:08 AM
Believe me, i'm gonna take my time with this shit so i can get it all right. I'll get everything thing i need piece by piece over time, asking lots and lots of questions aswell, and when the time is right, assemble it. I'm not gonna just buy, plug n play, not knowing what situation that i may put myself into. Gotta takes things one day at time.
Old 06-27-2005, 07:13 AM
wrightz28 - later on this week, thurs. is when i will buy them. I was supposed to get them last pay period, (paid bi-weekly and it sucks) but my father was hospitalized and i had to pay the bills at home, so no headers. But this time, im getting then as soon as get into work, 7:00am on June 30, 2005. Waited long enough, shit.
Old 06-27-2005, 08:42 AM
wrightz28's Avatar
Re: 305 Power Parts
I hear ya on how funding goes.
Honestly, my best suggestion to you 'cuz your treading unfamiliar territory here, I would recommend a master kit to restore the motor to as close to original output. And, as stated, some of the kits allow some wiggle room for a little more excitement, BUT, without the cost of trying to huddle pieces together seperately and end up disapointed as all hell when things aren't right. If there's one thing about wroking on a budget it's spending a whole lot a money and not getting anything out of it.
Old 06-27-2005, 08:46 AM
Pewter'01SS's Avatar
Pewter'01SS Pewter'01SS is offline
Yup...thats why my S10 hasn't had an engine under its hood for 3 years now.
R.I.P. Andy...It was an honor to have known you.
'01 Camaro SS - SLP Short Throw Shifter, Granatelli Air Lid, blue neon underbody kit
'92 Chevy 1/2 ton 4X4 - 350 w/ 190,000 miles and in desperate need of a rebuild.
'86 Chevy S10 - 350 w/ 400 Turbo trans, B&M Pro-Ratchet, 4.56 Posi, 350 is gone and slowly being replaced.
Old 06-27-2005, 09:18 AM
Where can i find this master kit?
