| Cavalier Problem Diagnosis Got a problem you can't fix? We can help. |
Hi all. This is about my daughter's 1997 Sunfire 2.2L OHV (96K miles, reasonably well maintained). It stopped running on her & wouldn't start. Checked fuel (OK); checked starter (OK); checked spark (OK).
Haynes manual says the next thing to check is the timing chain. 10 hours, several bruised knuckles, numerous scrapes and a significantly enriched vocabulary later, turns out they were right. Timing chain had a couple of broken links; no way the timing marks would align so apparently it had jumped timing, and the tensioner was almost fully extended. Replaced said chain; after several hours of rehearsing my new vocabulary everything was back together with all the timing marks aligned and everything all torqued right. Got in, sat down, turned the key and - no change, still wouldn't start. It cranks but won't start. I rechecked fuel, spark, starter - still OK. So, hoping to draw upon this forum's collective expertise, two questions: 1) Is it possible to put the timing chain & sprockets on - with the timing marks aligned - and be 180 degrees out of phase? 2) Is there anything else I should be chasing here? Thanks in advance for any and all help ... |
if it was 180 degrees out, i *think* it would at least be backfiring... wouldnt it be funny if all it was was a fuse...
i love my new sound system... Alpine type R 12" sub, Alpine deck, and MTX amp 2001 Z24 cavi, and it owns
Re: 97 Sunfire 2.2OHV Has Fuel, Spark, Starter & Won't Start
Re: Re: 97 Sunfire 2.2OHV Has Fuel, Spark, Starter & Won't Start
