Old 06-24-2005, 01:07 PM
rudiment5967 rudiment5967 is offline
Question about resin ?
Has anyone ever used Bondo fiberglass resin be used to cast model parts in molds? and if you did how did it turn out.
Old 06-24-2005, 01:28 PM
Scale-Master's Avatar
Scale-Master Scale-Master is offline
Not the hot ticket. Kicks off very hard, usually has lots of bubbles. Not sure about shrinkage... - Mark
Old 06-24-2005, 09:17 PM
mike@af's Avatar
mike@af mike@af is offline
Captain Over Engineer
Re: Question about resin ?
I've seen it done, but the results were moderate. I'd stick to casting resin.
-Mike
Old 06-24-2005, 09:53 PM
TEM50 TEM50 is offline
Agreed. Resin is the way to go.
Chris
Old 06-25-2005, 01:08 AM
evo8owner's Avatar
evo8owner evo8owner is offline
Send a message via AIM to evo8owner Send a message via Yahoo to evo8owner
A Little Off Topic, Can You Use Bondo On A Resin Body?
Old 06-25-2005, 10:36 AM
Yes, you can. But the finer higher end body fillers will work better.
Especially when it comes to feather edging... - Mark
Old 06-25-2005, 11:09 AM
freakmech's Avatar
freakmech freakmech is offline
Send a message via AIM to freakmech
also Bondo is very hot so use very small amounts at a time or you could warp the body.
Friends dont let friends buy die-casts...
"If it can't run 24hrs., it aint sh!t...." -me
