Go Back   Automotive Forums Car Chat > Nissan > 240SX | Silvia | 200SX(RWD) | Gazelle | 180SX
Old 06-24-2005, 11:39 AM
GSR2NR94's Avatar
GSR2NR94 GSR2NR94 is offline
Send a message via AIM to GSR2NR94
Squeaking Problem. Clutch??
My car makes like a whining or squeaking sound as I am accelerating through the gears. It startes at around 2100 rpm's and follows to about 3500 rpm's or so before it stops. Then, it starts up at around the same spot in every gear except 5th sometimes. It will just go away when I am in fifth or have hit my regular speed. It is only when I am driving also. Not when the car is not under load. I pushed the clutch in while going down the road though, and then reved it to about 5 or 6 thousand rpm's, and I could kind of hear it a little as the rpm's dropped for a second. I cannot figure out what this would be. I put a new clutch in a while back, could this my new clutch? Might I not have broken it in long enough (like break pads will do if they arent broke in well)? Any ideas? I appreciate the help guys. Thanks in advance.
"Drifting is a passion, make love to a corner."
Old 06-24-2005, 01:28 PM
TatII TatII is offline
even if the clutch is slipping you would not be able to hear any noises really. i can't be the pilot becasue cause that noise only happens when your in neutral and your rev up with the clutch engaged.
are you sure its not the belt screeching from the engine being under a load?
303whp stock internal KA-T
94 Acura NSX
Best E.T. 13.559
Best Trap speed 107.62 mph
Old 06-24-2005, 03:51 PM
GSR2NR94's Avatar
Re: Squeaking Problem. Clutch??
Well, I guess it could be the belts, but they are pretty new. I put new ones on less than 4000 miles ago. Maybe I will have to put some original Nissan belts on or something.
Old 06-24-2005, 04:44 PM
240SXSlideStar's Avatar
240SXSlideStar 240SXSlideStar is offline
You have to tighten the belts after you install them because they will stretch, it's like a month after you install then, you have to tighten them again.
-Jonathan
JDM Racing Motors inc
Montreal, Canada
www.jdmracingmotors.com
Old 06-24-2005, 06:50 PM
GSR2NR94's Avatar
Ok. I will try that and check back. Thanks.
Old 06-24-2005, 07:34 PM
SHIFT_KA24DE's Avatar
SHIFT_KA24DE SHIFT_KA24DE is offline
too bad the whining wasn't the spool up...
1993 RMS13 5MT KA
Old 06-25-2005, 10:28 AM
GSR2NR94's Avatar
lol. exactly.
