me and my buddy just picked up his new car, a 89 240sx. We knew it had a clutch problem so we towed it home. To me it doesn't sound like a clutch disc or anything like that. The guy that had it last said the slave, and master cylinder have been replaced, and the lines also. We bled the system through the little nipple by the tranny, and filled it back up with fresh fluid, then bled the system. We still are not getting any clutch pressure at all. Any ideas? we are trying to get it to work today so we can play with it a bit.
:edit: oh yeah, and that looping line in the clutch or whatever they had (I'm not into imports, the guy was talking about it) has been taken out, and redone. we did find a little leak there but we tightened up the joint there before we flushed and what not. |
Re: clutch problems
the master cylinder gives the pedal pressure, not the slave cylinder.
id say the guy bought a faulty master cylinder, or more likely he didnt bleed the master cylinder before he installed it.
that is not true. the clutch system is a hydraulic system. it needs to be totally sealed for pressure to travel and build. if you have a faulty slave cylinder, your pedal would sink straight to the floor and not pop back up ( mine did it to me on the highway ) if the seals are gone, then fluid would just leak out of the cylinders whether it be the master or the slave. this means theres no seal so pressure is just leaking out.
when you bleed the clutches, you need to bleed both from the master cylinder and the slave. this way you can get every pocket of air out. this would take alot of filling and building of pressure as the clutch initial will feel completely dead and keep on doing it till you start to feel alittle pressure build it up and keep on doing it till you get full pressure back.
303whp stock internal KA-T 94 Acura NSX Best E.T. 13.559 Best Trap speed 107.62 mph |
Re: clutch problems
yeah i agree but i was keeping it basic
the slave cylinder's only job is to return the fluid back to the master cylinder. pedal pressure is felt because of the sealed system, but the master cylinder has the piston that pushes the fluid, and the spring that helps push the piston back
![]() lol
![]() "I got that hustle in my genes like high blood pressure" -E-40 |
Re: clutch problems
hahahahahaha
Re: clutch problems
![]() yeah yeah blow me
Re: Re: clutch problems
Re: clutch problems
Getting back to the question at hand, depressing the clutch pedal would allow you to see the slave cylinder pushing the pin out and moving the clutch fork. If this is not happening, something is wrong with your line pressure.
1) fill the clutch fluid canister, the clutch master cyl should be bled by having your buddy put his foot on the clutch and bleed it at the master cyl output line. When the pedal sinks to the floor, tighten up the line, repeat 3 times. 2) top up the clutch fluid canister, bleed the slave cylinder in the same manner as before but using the nipple located on the slave cyl. Again test to see if the clutch fork moves? 3) If however, the clutch fork moves and you have no clutch dis-engagement, your clutch diaphragm or clutch assembly is faulty.
N14 Pulsar VQ35 conversion with major N/A upgrades, 6 spd FWD manual HLSD 18" Rims, big brake kit, Coil overs and freshly painted Smashed Black VY SS Ute ![]() The workhorse... Twin turbo 5.7L LS1 ![]() Boyd Coddington 19" Turbine Wheels AP Racing 4 Piston Brakes Tein Coil over Suspension HKS EVC 6 Boost Controller PLX Devices DM-200 OBDII Custom Front Mount Intercooler |
Re: Re: Re: clutch problems
that makes sense i just thought about it all the wrong way
