Old 06-24-2005, 10:31 AM
bobmga62 bobmga62 is offline
Serpentine belt replacement question
I plan on changing my serpentine belt this weekend on my 96 blazer.. in the past dealers have ripped me off on this
I understand I just need a pry bar to treverse the tension on the spring in the tensioner... is this correct..
does anybody out there have the trick to do it....
thanks
Bob
Old 06-24-2005, 10:39 AM
TonyMazz's Avatar
TonyMazz TonyMazz is offline
Re: Serpentine belt replacement question
thanks
Bob
For my 99......
No trick really , what I do is take a 3/8" ratchet with a 1" extension, insert into the slot on the tensioner and pull, moving the tensioner inward. Take the other hand and pull off of the idler pulley, release the tensioner and work the belt off.
Slide the new one on over all the pulleys except the idler, use your ratchet/extension move the tensioner inward again and put the belt under the idler and volia you are a serptine expert.
It takes me about 15 minutes total, including a sip of beer to do mine..and I do it about every 45-50K or when I think the belt is getting ragged.
1999 Blazer LS 4WD 4.3L "W"
2004 Silverado 2500HD Duramax
Old 06-24-2005, 11:07 AM
Thanks Mark..
I think the sip of Beer is the most important factor.... especially here in the Norteast we're supposed to hit 100 degrees tomorrow.. (& last night it was 50!!)))
thanks again!!!!!!
R
Old 06-24-2005, 02:03 PM
blazee's Avatar
blazee blazee is offline
Problem?
It only takes me a couple minutes. I don't use a ratchet, I just push the tensioner in with my left hand and pull the belt off the idler with my right. Remove the old one, route the new one, leaving the belt off the idler, then I push in the tensioner with my left hand and slip the belt on the idler with my right. piece of cake.
Old 06-24-2005, 02:15 PM
TonyMazz's Avatar
Re: Re: Serpentine belt replacement question
Must be because you take "enhancement" drugs haha.....
Old 06-24-2005, 02:21 PM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
Remember to put the rachet on the rotating part of the tensioner to spring it back. The part that is in contact with the belt.
1995 Factory Blazer Service Manual for sale, PM if interested.
Old 06-24-2005, 02:23 PM
blazee's Avatar
Problem?
Re: Re: Re: Serpentine belt replacement question
Old 06-27-2005, 08:21 AM
Allbert Allbert is offline
I do it the same way, except I use my right hand to push on the tensioner and my left to handle the belt. I've always been impressed with how easy this maintenance task is on the S-10s and Blazers.
