Go Back   Automotive Forums Car Chat > Toyota > 4Runner/GX470
Old 06-24-2005, 10:02 AM
stb1134 stb1134 is offline
antenna motor
I have a 97 4runner with 109,000 miles. The antenna will not go up and down, but the motor is running and grinding. Should I replace the antenna motor, or disconnect the motor? If I just disconnect the motor, will it also disconnect the radio?
Old 06-27-2005, 11:05 AM
fourwd1's Avatar
fourwd1 fourwd1 is offline
AF -Advisor
It's probably the mast, not the rotor. You can disconnect the motor, the harness should be under the pass side front fender. Won't hurt anything.
84 4Runner - ARBed 5.29s F&R, 4.7 & 2.28 t-cases, Chevys, AP x-over, BudBuilt x-member, 2" drv trn lift, 36" TSLs, 30 spline Longs
80 something p/u - Buick 231 V6/TH-350 trans, Holley 4 bbl, Weiand intake, dual batts, dual tanks ...
89 4Runner - stock
2000 Isuzu Trooper + 2010 Sonata
Old 07-01-2005, 12:34 PM
ldytigress495 ldytigress495 is offline
Send a message via AIM to ldytigress495
Re: antenna motor
yup, sounds like the mast is broken. from what i've heard, a lot of people have had the same prob- including me. Why don't you replace the mast? It's a bit expensive at the dealership (labor is more expensive than the mast itself) , so i recommend taking it somewhere else.
Old 07-01-2005, 09:40 PM
Brian R.'s Avatar
Brian R. Brian R. is offline
Resident Chemist
Send a message via Yahoo to Brian R.
Re: antenna motor
Interesting idea:
http://www.toyotanation.com/forum/t65507.html
Forum Guidelines:http://www.automotiveforums.com/vbulletin/guidelines.html
"What we've got here is a failure to communicate"
Old 07-01-2005, 10:44 PM
jtoyotaman jtoyotaman is offline
Re: Re: antenna motor
you can buy a mast cheap on the internet, very easy to install
