Go Back   Automotive Forums Car Chat > Ford > Crown Victoria
Old 06-24-2005, 09:45 AM
Pittwoman Pittwoman is offline
No one can fix my cruise control on my 99 Crown Vic
I have had my '99 Crown Vic in the shop 6-7 times, trying to get my cruise control fixed. Is anyone aware of known problems with the cruise control in these cars? A switch in the steering wheel was replaced and a new servo? (not sure if that's right) put in. Help!!!!
Old 06-24-2005, 11:50 AM
cobradude360's Avatar
cobradude360 cobradude360 is offline
Send a message via AIM to cobradude360
does your horn and air bag still work or is you air bag light on ans flashing? im willing to guess its a clock spring
THE 92 grand marquis LS M75 with the 281 romeo v8 u cant mess with that
MODS: dynomax bullit exhaust, custom intake, polished upper plenum, 180T-stat, accel coil packs and platnum plugs
also 2005 crysler sebring sedan walter p crysler edition yea its got the 2.4 pics comin soon
Old 06-24-2005, 01:07 PM
Re: No one can fix my cruise control on my 99 Crown Vic
The horn works and the air bag light is not on. Should there be a light that comes on on the dash when the cruise control is turned on? Because no light has ever come on, even when it was working intermittently.
Old 06-24-2005, 01:47 PM
way2old's Avatar
way2old way2old is offline
TOKEN HILLBILLY
Check pins 6 and 10 on the cruise control servo. These are ground pins for the cruise. Use an ohm meter co test continuity to ground. Also check to be sure all cables are routed properly.
Being way2old is why I need help from younger minds
The sooner you fall behind the more time you'll have to catch up.
HEY Y'ALL--READ THIS
Here are some of our old vehicles for sale.
Old 06-24-2005, 01:48 PM
way2old's Avatar
TOKEN HILLBILLY
Check pins 6 and 10 on the cruise control servo. These are ground pins for the cruise. Use an ohm meter to test continuity to ground. Also check to be sure all cables are routed properly. Check the stop light switch for proper operation.
Old 08-19-2005, 01:59 PM
djgdjg djgdjg is offline
hope i can help we just fixed a 1999 crown vic today with the same problems. our fix was the deactiontor switch, on shop key the wiring diagram shows it under the brake fluid reservoir this was wrong on our crown vic. on 1998 and above it is under dash on the brake pedal support it will be on the left side it will not be the brake pedal position switch. the wires colors will be orange and Lt grn/red. to make sure this is it undo the switch plugin and jump the switch with a jumper wire and test drive. caution!!!!! with this because the cruise will work and the only way to turn it off is to hit the off switch on steering wheel as the brake pedal will not shut it off. be carefull!!!!! the part is dealer only about 16.00 to 33.00 dollars hope this helps have a good day dennis
Old 08-19-2005, 02:13 PM
Hollowcreek Hollowcreek is offline
There was a recall on one of the cruise control deactivation switches causing vehicles to catch fire. I think it was the one that is out by the master cylinder. Make sure you get the proper replacement.
