Old 06-24-2005, 08:53 AM
ejfenz ejfenz is offline
S-10 Blower Motor
I have a 1990 S-10. I had the motor on Low, and got a small puff of smoke through the vent duct.
I assumed that I burned the motor up so I replaced that - I checked the 25A fuse in the cab and the 25A in the engine. Did I fry something else, or did I just get a bad Chinese motor from the store?
Old 06-24-2005, 10:43 AM
OverBoardProject OverBoardProject is offline
Banned
Re: S-10 Blower Motor
you'll have to run a jumper wire with a inline fuse on it to test the motor
Old 06-24-2005, 02:06 PM
dmbrisket 51's Avatar
dmbrisket 51 dmbrisket 51 is offline
Send a message via AIM to dmbrisket 51
goto autozone (i know, i dont like to either) and put out the 90 bucks or so and get a lifetime warrentied one, never need to pay for it again, no matter howmany times the forigners screw it up... but to test, do as overboard said, or take it out and run a power sorce to it directly to see if it spins or not
Old 08-01-2005, 07:34 AM
Re: Re: S-10 Blower Motor
I replaced the motor with a Canadian one - works fine but I still have smoke at the fan speed switch. I replaced the switch (the old one had burn marks). The new switch is still smoking. What can cause my switches to fry?
Old 08-01-2005, 09:35 AM
Banned
If you can use a multi meter try using it to bypass the switch, and check how much current that you have.
My guess is to much resistance in the wire somewhere, probably almost burnt out somewhere. Probably by the switch, or the fan motor
Or you could have too much amprage there, which I really can't see happening.
