Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 06-24-2005, 08:00 AM
doogcat doogcat is offline
95 2g eclipse wont start
Hello iam sorry about my grammer. The problem i am having on this 1995 eclipes with a 2.0 2g motor, with manual transmision . The motor was out of the car for two years. When i went to start the car, i am only getting spark when you let off of the key. I checked the coil, cam and the crank sensor's they are all ok . One thing i did notice is that if i have the key on and unhook and rehook the cam or crank sensor .the fuel pump will run and i will get a quick spark . Iam lost please help and i am sorry about my grammer ?????????????????????????????
Old 06-24-2005, 10:38 PM
macder macder is offline
Send a message via MSN to macder
Re: 95 2g eclipse wont start
You past/present English teacher should help you first.
1993 Eagle Talon ES (4g63NA)
14.6 @ 98 mph (110 octane race fuel)
-5 Speed Transmission (From a 4g67)
-Stage 2 Crane cams
-Ported and polished head
-Aggresive valve springs
-2.5" Custom made exhaust piping
-Custom header
-Gutted catalytic converter
-Bored 0.5mm
-Advanced ignition timing (CAS) aprox. 5 degrees (set @ ~10deg BTDC)
-2g valve lifters (Lifter noise returned, now it a true DSM)
-K&N w/modified air canister
Old 06-25-2005, 12:02 AM
l_eclipse_l's Avatar
l_eclipse_l l_eclipse_l is offline
Re: Re: 95 2g eclipse wont start
Great post, this helped the guy out a lot.
Plus, your English was not perfect either. "You past/present" should have been "Your past/present".
To the guy that originally posted:
Edit your post, throw some punctuation in there, that might help people understand what your tryin to say. Hard to help until you do that.
'92 3000gt SL
Zoom Stage 1 Clutch
Originally Posted by kjewer1
I disagree. Better is better. Bigger is just bigger.
I just made that up, and I like it.
Old 06-25-2005, 11:11 PM
It's not that I'm not willing to help him out, but a problem well stated is a problem half solved (Kevin, that's your quote, but I just had to use it this one time). As for your problem doogcat, try to re-state your problem being more descriptive and plenty are willing to help you.
-Stage 2 Crane cams
-Custom header
-Bored 0.5mm
