Old 06-24-2005, 02:36 AM
carnut04 carnut04 is offline
Paint Question
I want to paint my car gloss black. I also want to clear coat it. Should I polish out the paint if theres orange peel before I clear coat it or after? Thanks
Old 06-24-2005, 03:54 AM
proosen's Avatar
proosen proosen is offline
Re: Paint Question
Do not polish between paint layers as it could leave some ressidues on the surface that will destroy the finish for you. Just sand it with some fine grit wet and dry paper to obtain an even dull surface before the clear coats. But as it's a solid colour there really is no need for a clear coat, just put on additional coats of black instead and polish it out.
Good luck!
Niclas
Old 06-24-2005, 05:25 AM
sjelic's Avatar
sjelic sjelic is offline
Re: Paint Question
That is true you will risk one more thing if you decide to clear coat and that is dust. Black is not forgiving colour if not treated clean.
Sasa Jelic
SCALEMAKERS
Old 06-24-2005, 07:56 AM
klutz_100's Avatar
Re: Paint Question
wow wierd!
I was thinking of asking the exact same question myself this morning!
I'm having a hard time getting my black Boxster to the shine I was hoping for and was wondering if I can clear it after polishing. Now I know the answer - NO!
Black is definitely a hard colour to work with in 1/24 as in 1/1 (my car is black and it looks dirty 2 hours after the carwash )
Old 06-24-2005, 08:29 AM
mickbench's Avatar
mickbench mickbench is offline
Re: Re: Paint Question
Originally Posted by klutz_100
wow wierd!
I've worked with black, and I just applied a few extra coats, and worked slowly when I was polishing the paint. It takes long time, and Tamiya Ultra Fine Compound works a treat.
Clear coat isn't needed, just lay down some extra paint - should do the trick, did for me.
Old 06-24-2005, 08:33 AM
Scale-Master's Avatar
Scale-Master Scale-Master is offline
You can clear it after it has been polished.
Make sure there is no wax residue, (if you waxed it).
You can remove it by washing with detergent and water, but I prefer to also use rubbing alcohol, the cheap diluted stuff.
It will aid adhesion if you carefully wet sand with 2000 grit sandpaper, but I have done it without sanding and gotten great results... - Mark
Old 06-24-2005, 08:39 AM
white97ex's Avatar
white97ex white97ex is offline
Send a message via AIM to white97ex Send a message via Yahoo to white97ex
Re: Paint Question
i typically clear all of my paint. and i have polished the paint out before clear with 1500 then 2000 and followed with 3m rubbing compound. and then washing the body and have yet to have a problem
My name is Russell, feel free to use it.
I'd rather be hated for Who I Am than be loved for Who I Am Not
