Old 06-24-2005, 12:39 AM
andy2040 andy2040 is offline
no acceleration when hot
89 1.9L when warm has no acceleration whatsoever,will
not go up any hill over 5MPH...changed coil,wires,fuel pump
if I do not accelerate it wil gradually increase spead, filters ok,
trans fluid good
HELP
Old 06-24-2005, 02:39 PM
frafreg frafreg is offline
Re: no acceleration when hot
Hmmmnn, I need a little more information like did this problem just happen suddenly or did it happen over a period of time. Does the engine idle okay or is it missing and so on. Make sure you don't have a blocked exhaust. It could be blocked form the catalytic converter back or someplace else. Hope this helps.
Old 06-24-2005, 02:43 PM
mightymoose_22's Avatar
mightymoose_22 mightymoose_22 is offline
Ya... describe what happens when you go uphill... does the engine wimp out and die? Does it race but just not go anywhere?
Does the car drive fine on the highway, and at all other times on level ground?
Old 06-24-2005, 11:00 PM
Re: Re: no acceleration when hot
Uphill wimps out to 5 MPH....on level road can increase the
speed as long as I do not accelerate..if so will decrease speed and die down
seems like a plugged fuel filter problem sympton...shifts gears at
the right range ..just cannot depress the gas pedal or it will die down..
can the tranny bands slip intermittently?? if I shut down for 10 minutes
then go it will ragain power but will still die if I give it too much gas
Old 06-25-2005, 08:03 AM
AnneJac AnneJac is offline
EGR valve?
Did you try the EGR valve?
I had one stick once and the car ran like garbage.
They can stick open or closed and really mess up the air intake process. You will get sympotms similar to a vacuum leak- but if you look all the vacuum hoses and whatnot are connected.
Maybe try that. It could be the valve itself- or one of the electrical components that regulates it (depends on what year your car is).
Hope I helped a little...
Old 06-25-2005, 08:41 AM
Thx for info..it is an 89 escort...idles ok..trouble started
happening around 40/50 MPH range..step on gas and it would
do nothing ...back off on gas and it would gradually pick up
speed...now happens usually at any speed
Old 07-10-2005, 06:15 AM
AzTumbleweed's Avatar
AzTumbleweed AzTumbleweed is offline
If you have a good fuel filter then I'd suspect a clogged vent line. Next time it does this try taking off the fuel cap. See if there is a big sucking sound. You know, like Washington, DC makes
