Go Back   Automotive Forums Car Chat > Ford > Thunderbird
Old 06-24-2005, 12:29 AM
jedimaster26 jedimaster26 is offline
shifter knob removal
I have a 1993 tbird auto tranny and i was wondering if their is anyone here who know how to remove the knob on the shifter?
Old 06-24-2005, 05:41 PM
97Bird's Avatar
97Bird 97Bird is offline
Re: shifter knob removal
I don't know if the 93 is the same as a 95-97 but maybe this will help. The O/D switch is removed by gently prying between the switch housing and the gearshift lever knob. There is a u shaped retaining clip on the front side of the gear shift knob that has to come out. If you put the shift lever all the way back it will be easier to see the slot that it is in. After removing the clip, push in the release button (the button you have to push when moving the selector back and forth) and then pull up on the gear shift knob.
Old 06-25-2005, 05:09 AM
corder13 corder13 is offline
Send a message via ICQ to corder13 Send a message via AIM to corder13 Send a message via MSN to corder13 Send a message via Yahoo to corder13
Actually, the '93 doesn't have the overdrive switch. I used to have one. All you do to get the shifter knob off is press in on the thumb-switch on the side of the shifter knob (as far in as you can go), then pull straight up. If it's never been off before, it'll be stiff, but just keep pulling. It may help to turn the shifter knob VERY SLIGHTLY while pulling up on it.
Rick
Old 12-30-2005, 05:48 PM
Hood2 Hood2 is offline
I'm trying to replace one on a 94 T-Bird, but the new one doesn't want to go down all the way so that I can get the clip back in.
Is there a trick to this?
Thanks
Old 12-30-2005, 07:06 PM
I would try pushing the shifter button in and pushing down. Then release. If it still isn't down all the way, you can do what I did on mine: give it a good firm smack on the top of the shifter to get it on the rest of the way.
Rick
Thanks
Old 12-30-2005, 10:08 PM
overl0rd overl0rd is offline
Re: Re: shifter knob removal
Patience, patience, patience. If it don't wanna go dont make it, figure out why it don't.
