Old 06-23-2005, 05:24 PM
Demos Demos is offline
stutters, stalls - 1993
Hello.
Having a problem with my 1993 Chevy Lumina, 3.1 liter. 132000 miles.
Started car, had trouble keeping it going - parked it, tried later, worked fine, later in the day I had the same problem. Go figure.
Sounds like all the cylinders are not firing, to me.
Car is shooting un-burnt fuel vapor from exhaust something fierce. Also has low horse power. Takes forever to get moving, and dies anytime the RPM goes low.
Replaced spark plugs and wires, no help.
Any ideas?
Old 06-23-2005, 06:06 PM
jeffcoslacker's Avatar
jeffcoslacker jeffcoslacker is offline
Lactose the Intolerant
Re: stutters, stalls - 1993
Coilpacks and module, next step. Try to see if you've got two cylinders on the same coilpack misfiring.
You made three mistakes. First, you took the job. Second, you came light. A four man crew for me? F**king insulting. But the worst mistake you made...
...empty gun rack.
Old 06-29-2005, 03:23 PM
jhouston77 jhouston77 is offline
Re: Re: stutters, stalls - 1993
Could be the timing chain. That's wat the mechanic said mine was.
Old 06-29-2005, 04:15 PM
mattsdominion mattsdominion is offline
Re: Re: Re: stutters, stalls - 1993
Unless your timing chain is slapping, or has skipped a tooth or two...
it isnt the timing chain.
Old 06-29-2005, 05:24 PM
cadgear's Avatar
cadgear cadgear is offline
If the timing is off, usually you won't have a time where it'll run good. It'd be fairly consistient with its refusal to start.
Old 06-30-2005, 06:18 AM
Checked coil packs, one was fine, one was weak, one was dead. Replaced all of them. Ran fine, then about 5 miles later, started back up again.
Used a paperclip to get a code on it, got a code 15 - somthing about the Temp sensor for the coolant. Replaced that, again it worked for a bit, then crapped back out.
Any more ideas?
Old 06-30-2005, 06:22 AM
Any more ideas?
Ignition module or crank position sensor next most likely, check the wiring between them before replacing either.
...empty gun rack.
Old 07-01-2005, 03:12 PM
richtazz's Avatar
richtazz richtazz is offline
stupidity should hurt
if you have a fuel pressure tester, check fuel pressure. If the fuel pressure is fine, then I agree with Jeff, crank sensor first, module next. If fuel pressure is low, pinch the return line. If the pressure rises, the regulator is bad. IF pressure is still low, you need a fuel pump.
Old 07-11-2005, 08:43 AM
Having problems finding the crank position sensor, could anyone tell me where to start looking?
also, been digging deeper into it, looking at the fuel injectors right now. Not sure why, but both leads are hot? why is this?
Old 07-18-2005, 12:44 PM
OK, Replaced the Crankshaft sensor, coil packs, 02 sensor, ignition mod, catilist converter, coolant temp sensor, Throttle control sensor, Checked the injectors and fuel rail, and also replaced the ECM. No dice yet.
Where should i go next?
Old 07-18-2005, 02:39 PM
fourleaf033 fourleaf033 is offline
im haveing the same type of problem with my 93 lumina euro 3.1
new: plugs, cat, map, iac, tps, fuel filter, air filter, computer,crank sensor
checked: coils, ignition mod
next to try: plug wires, coolant temp sensor, cct
its becoming a real pain in the butt
problem is as follows.... when just started car runs on high idle for about 10 sec then drops to about 600 where it surges between 500 and 700
when in any gear it will surge from 300 to 700
when driving and coming to a stop with will stall out
when just in idle the engine seems kinda shaky like maybe a cylinder is down, but when i pull every plug one at a time nothing changes
Old 07-18-2005, 02:40 PM
Old 07-18-2005, 06:03 PM
xtimgx xtimgx is offline
Send a message via AIM to xtimgx
tcc solenoid? i've been reading a lot of posts on here about these solenoids on the torque converter or something like that. if anyone knows how to take the wire out of the solenoid, please tell me, so i can do this-timg
Old 07-19-2005, 01:16 PM
ashypete ashypete is offline
I have a 93, and had the same problem you have. I found that the #4 cly was dead. I changed the coil pack for that cly, but it didn't help. I then changed out the ignition control module, and now my Lumina is back to it's old self. No more problem. I have 132,000 miles on this old girl. Good luck the control module is a bear to change.
Harry
Old 07-19-2005, 08:50 PM
ACEMAN8822 ACEMAN8822 is offline
I am suprised no one said check knock sensor?
