Go Back   Automotive Forums Car Chat > Honda > Let's get Technical!
Let's get Technical! Discussion for hardcore in-depth motor heads!
Old 06-23-2005, 04:24 PM
Nackattack Nackattack is offline
Accident....NOooooo!!!! Please help Map sensor?
ALrighty so I just got in a damn accident two days ago. I got some gsr rims and went to replace the tires but they only had 2 so put them on the front two wheels. Was getting on an onramp for the free way that curves and is sloped downhill. Rear wheels lost complete tration and I did a 540 and smacked the crap out of the rear right bumper. Scraped the front pretty good too. Anyways after the whole ordeal was over I noticed my engine light was on. I checked the code and got 3 MAP - manifold absolute pressure sensor What is exactly am I looking for here. Should I not be driving the car? Want to get this fixed before I do anything else. Any help would be greatly appreciated.
Old 06-23-2005, 04:35 PM
Re: Accident....NOooooo!!!! Please help Map sensor?
If I reset the ecu if the problem still presists the ecu light will come back on correct. I don't want to just reset it and ignore any problem that is still there.
Old 06-25-2005, 11:57 AM
Privatebigandrew's Avatar
Privatebigandrew Privatebigandrew is offline
Send a message via AIM to Privatebigandrew Send a message via Yahoo to Privatebigandrew
correct
94' Del Sol VTEC (B16A3) SOLD.
Accel plug wires, NGK iridium IX plugs, AEM short ram intake, DC sports ceramic coated header (4-2-1), Airmass high flow cat ,Custom Magnaflow exhaust, Bosal Brospeed tips, Neuspeed short throw shifter, Tokico clutch master cylinder, Tokico clutch slave cylinder, Prothane complete kit bushings, Brembo front rotors, NR EL-Glo instrument gauges, CTR LSD trans with ITR final drive, Exedy chromoly flywheel, ACT HDSS clutch kit, Raxle axles.
Old 06-25-2005, 02:05 PM
Re: Re: Accident....NOooooo!!!! Please help Map sensor?
Originally Posted by Privatebigandrew
correct
Thanks for the response. I checked all my conections to my throttle body and reset my ecu. No light Yes!!!! Now I just need to find a good body shop and a place in the seattle area that sells body kits!
