Silverado Fuel injectors
I have a '99 silverado with the 4.3 engine. When I first start it up in the morning, it will buck and stumble for the first 4-5 min of operation and then settles out and runs fine the rest of the day. I've tried fuel injector cleaner with no appreciable improvement. I've heard and read that the fuel injectors on these vehicles were poorly designed and tended to fail. I have seen advertising for replacement injectors and would like to get some advice:
1) Is this injector design prone to failure? 2) The dealer want's $800 to replace the injectors - but I'm not inclined to simply pay that amount of money to replace a bad design with another badly designed OEM.. Does anyone have any experience with aftermarket fuel injectors? Many thanks. |
Re: Silverado Fuel injectors
i would first make sure it is the injectors.....when you say it bucks and stumble do you mean ruff idle? does it die on you?
There is a procedure to unstick the valves (your GM dealer has the tools and procedure) What happens is hydrocarbons build up on the poppet balls and cause them to stick inside the seats. Now there is an updated injector assembly that replaces the old design and eliminates the poppets...if you are going to keep the vehicle for any period of time its worth the money to have the update done.
Why do you never have enough time or money to do the job right the first time, but enough time and money to do it again? Got all the certifications 25 years ASE Certified Master Technician GM WCT Yea..I work at a DEALERSHIP....got a problem with that? Want to diagnose cars like the Pros? FOR SALE: OTC Perception 2 channel Labscope (badged as a Matco Reality) This is my personal labscope that I use to diagnose waveforms, like new, comes with leads and training video PM Me for details |
Re: Re: Silverado Fuel injectors
The engine seems to idle fine on a cold start. But as soon as I start driving - even with very gentle acceleration - it's clear that one or more cylinders aren't firing. If I let it idle - or drive it - for two or three minutes, it then runs fine and will continue to for the rest of the day. Next morning, same story.
Can you recommend a source for these if they are aftermarket? Many thanks again for the full story on the problem. DT |
i have the same problem only it seems that i get it when i start the vehicle warm instead of cold and it idles rough after ive driven it for a while, if i have the same problem am i losing performance during driving?
