Go Back   Automotive Forums Car Chat > Oldsmobile > Eighty Eight
Eighty Eight Includes the '97-'98 Regency and '96-'99 LSS Models
Old 06-23-2005, 01:54 PM
hepps hepps is offline
Question power windows wiring
Due to almost 20 years of opening and closing of doors the wiring to the front drivers side door has been sliced so I can't control any window from the drivers side. I pulled the rubber boot off the wires and found the pink(hot) wire cut along with the purple/black one. is there a way to remove the connector to the car so I can easilly get at those wires to splice them together? any sugestions would be helpful
Old 06-23-2005, 02:56 PM
Alibi's Avatar
Alibi Alibi is offline
Send a message via Yahoo to Alibi
I assume your car is a 1985? I believe you have to take off the lower dash from your car to access the connector.
To do this, you have to remove the 4 bolts holding the vent panel in, then remove the 30 or so bolts holding the lower dash in only after removing the vent panel (lower dash as in the section w/ the glovebox and ashtray). You should be able to access the connector then -- it has lots of wires coming out of it (duh) in the area of the door...on my car the connector is tan-colored.
As far as popping the connector off, i haven't done it--but i believe you can just pry it off w/ a screwdriver. There might be a screw at the bottom, but i'm not sure...
Well, good luck and let us know b/c I need to replace a door of my own pretty soon
-Eric
89 LeSabre T-Type: CAI, STB, F41 Suspension, Moog Ball joints and tie rods, dual-out flowmaster and dual tips, Pointiac CD HU, Delco type 2 Ignition, etc.
Basic H/C body info:http://www.3800power.bravehost.com/index.htm
http://www.cardomain.com/ride/2318168
Old 06-23-2005, 03:36 PM
joe4speed joe4speed is offline
Send a message via ICQ to joe4speed Send a message via AIM to joe4speed
Re: power windows wiring
An easy way to splice them together in a tight spot is to use Quick Splicers.
Joe!
1988 Mustang GT
1993 Olds 88 LSS
http://www.joe4speed.com
Co-owner: RiceHatersClub
