Old 06-23-2005, 12:59 PM
CrissCross's Avatar
CrissCross CrissCross is offline
Send a message via ICQ to CrissCross Send a message via AIM to CrissCross Send a message via Yahoo to CrissCross
Unhappy 98 Caravan no power to coil
Hello every one.
Well I need some help. I have a 98 Cravan that will not run. It will turn over but not run. I have sofar narrowed down the following.
I get almost 12 volts power to the coil when the key is turned on then almost imediatley the power goes away.
This all started when I tried to by bass the wiring to the AC to see if the compresser was dead or not considering it was not working. I checked all fuses and relays all seems well.
Any one have any ideas?
Old 06-26-2005, 08:27 AM
CrissCross's Avatar
Ok News Update:
I checked all the fuseable links and did not find any thing. I went and got a chilton manual so that I could get the wireing spec and found that the black wire with the blue stripe is ground so I checked so I checked resistance to a ground strap and every point where I could find this black wire with blue strip. I found that with the CrankShaft Position sensor disconnected that the resistance went down to like 3 Ohms and with it connect was like 11 or 12 Ohms So I ordered a Crank Shaft Position Sensor I will replace it latter today and will let you all know the out come.
Old 06-29-2005, 02:39 AM
Reckelstekle Reckelstekle is offline
Re: 98 Caravan no power to coil
If you have no power to the coil then you may have a bad pcm.
