Go Back   Automotive Forums Car Chat > Ford > Expedition
Old 06-23-2005, 11:38 AM
sam sanders sam sanders is offline
rear window wiper
The rear window wiper, works when it wants to, presently it isn't working. I took it for twice while was under warranty and it worked for a little while, then it only worked when it wanted to. Is there anyone is having this problem? Has anyone had this problem solved? Please help!!!
Old 06-23-2005, 02:09 PM
hot91sentra_xe hot91sentra_xe is offline
Send a message via AIM to hot91sentra_xe
Same problem!
I have a '99 expedition and I have that exact same problem. I'm wondering if the problem is with the wiper itself or the wiper switch.
Old 07-13-2005, 05:41 PM
shoguy_ shoguy_ is offline
Re: rear window wiper
When mine doesn't work. I go to the back of the vehicle and pull on the arm. Then it starts going and works for a while. I've only had to do this twice in three years though
Shoguy_: '91 SHO + w/only 85000 mi.(sold to a buddy 11/01/05),now driving wifes 2000 New Beetle, and added 2000 Volvo Cross Country.
Old 07-15-2005, 10:35 PM
Psycholes Psycholes is offline
Wow I thought I was the only one with this problem!! Anyone have any solutions for this??
Old 07-19-2005, 08:23 PM
js_318 js_318 is offline
I have a 1997...and have the same problem..any solutions?
Old 11-18-2005, 03:33 PM
critterkeeper64 critterkeeper64 is offline
Talking Re: rear window wiper
So Im Not Crazy, Im Not Crazy!!!!!!!!
Old 11-19-2005, 03:10 PM
willdog5 willdog5 is offline
I have the same problem on my '00. I think the problem involves the opening of the rear hatch or the rear window. Sometimes "fiddling" with the release will start the wiper working. Sometimes opening and closing the hatch or the window will start it working. Most of the time however, the only way to get it working involves standing in the pouring rain gently forcing the arm until it begins to operate... until the next rainstorm.
Old 06-23-2006, 06:58 AM
Chestermom Chestermom is offline
I thought it was a Poltergeist!
2000 EB Expedition does the same thing
Mine rear wiper only works in bad weather -- when it's a great day it sounds like it has a dead motor
Old 07-13-2006, 09:30 PM
salttl1000r salttl1000r is offline
I have the same problem. I took the wiper motor out and tryed to see if there was a place to oil the motor bearings or gear assembly. There wasn't any visible place to put any oil drops. I could make the wiper motor work if I tapped on it and that was it. No success. I plan on getting one from a local junk yard.
Old 10-27-2006, 08:20 PM
factor8 factor8 is offline
I have the same problem too. I actually learned to pull the wiper arm down from this site; but, I have to do it twice a week. I just got a wild hair up my R's and decided to remove the wiper from the motor mount and reset it about 1/4 inch lower. So far it works great and I'll keep you all posted. Hopefully it does the trick.
Old 11-01-2006, 08:12 PM
I think that was the trick! I used to have to tug at it every other day. Now, I have no problem what-so-ever. It makes me think that the arm drops too low and somehow throws the gear shaft out of alignment. Keep in mind that I am not a mechanic and I usually have a bolt or two left over when I take anything apart. I can work on people but not machines go figure!
Old 11-26-2007, 10:00 AM
MTrachy MTrachy is offline
I have a 2003 Expedition and I had the rear wiper stop working. I could tell that it was the wiper itself since when I open the window portion of the rear gate and tried to move the wiper it was very stiff. So I dismantled the wiper from the rear window. By removing the 'c' clip that holds the shaft of the wiper in the widow, I was able to remove the entire mechanism from the window. I used some 600 grit sand paper to smooth out any roughness from the shaft. I then applied some lithium grease to the shaft and re-assembled the wiper. All in all it only took me about a half hour to do and the wiper works well now. MT
Old 11-26-2007, 10:22 AM
JoeShmoe's Avatar
JoeShmoe JoeShmoe is offline
Send a message via AIM to JoeShmoe
You guys probably left the arm hanging off the arm rest for the wiper. I kow i did when i washed it once, that probably threw out of alignment and i have to tear it apart. I believe its fixable.
'98 Contuor SE, 2.5 V6 Auto Silver
'08 Altima 2.5S, Auto Super Black
