Go Back   Automotive Forums Car Chat > Volkswagen > Beetle - Air Cooled > Type 1
Old 06-23-2005, 10:40 AM
slaterxx slaterxx is offline
Connecting electronic Tachometer
I just did swapped engines and did not mark the tach wire. I need to know if this is connected to the positive or negative side of the coil. Thanks
Old 06-23-2005, 11:39 PM
trooperbrett trooperbrett is offline
Re: Connecting electronic Tachometer
I just went to check mine, cuz I couldn't remember off the top of my head. The tach is hooked up to the same terminal as the condenser from the distributor.
If I remember correctly one terminal is 12 Volts from the car, the big middle one is gobs of volts to the distributor (and then to the spark plugs) and the other one is the pulse from the condenser to tell the coil when to fire, that's the one you want.
A tach is a good upgrade, I never drive a VW without it.
Brett
Brett
No Matter Where You Go, There You Are
[IMG][/IMG]
Old 06-23-2005, 11:48 PM
Rick's69's Avatar
Rick's69 Rick's69 is offline
Send a message via AIM to Rick's69
where do bugs redline?
Old 06-24-2005, 12:18 AM
It really depends on what motor you have, the stock motor CAN'T go over 4000 RPM or the valves will float, smack the pistons, the crank will come apart and the whole thing will go up in a huge fireball! (just kidding, but it'd be cool, no?) If you have a counterweighted crank, stock or stroked, AND high rev single or double valve springs you can go higher. Single springs are good to 6000, I've heard, but I haven't tested mine. I keep mine (1776 dual port high rev single valve springs, counterweighted stock stroke crank, mild cam, Webers) below 5000 cuz I need it to run everyday. The dual springs are supposed to be good to 8000-10000. So the limiting factors are the valve springs and the crankshaft, also, to a lesser extent, the cam.
So, in a nutshell:
Stock motor below 4000 RPM
Mild Preformance motor 5-6000 RPM
Stroker Street Screamer 8000+ RPM
Good luck, and drive your bug everyday!
Brett
[IMG][/IMG]
Old 06-24-2005, 11:25 AM
Tach connection
Brett,
Thanks for your help..
Dave
Old 06-24-2005, 11:14 PM
Rick's69's Avatar
cool thanks.
