Go Back   Automotive Forums Car Chat > Jeep > Grand Cherokee | Grand Cherokee SRT8
Old 06-23-2005, 09:29 AM
dowdel dowdel is offline
Angry Interior dome/map lights constantly on
Has anyone seen this before? The interior map and dome lights all stay on when I'm driving. The dimmer switch has no affect, and the lights don't ever go off until the jeep is parked and turned off for about 10 minutes. I've checked the fuse and it's fine. I've also tried resetting it by pulling it out, nothing............
Anyone?
I'm desperate here.
John
Old 06-23-2005, 09:30 AM
I forgot to say this is a 1998 Jeep Grand Cherokee
Old 06-24-2005, 03:04 AM
SteveB05's Avatar
SteveB05 SteveB05 is offline
Re: Interior dome/map lights constantly on
Does the VIC show any open doors or hatch?
Steve
'98 JGC (ZJ) 5.2L, Aluminum Radiator w/Electric Fans, 4" Cowl Induction Hood Scoop, Custom High Flow Air Filter, Magnaflow Cat / Flowmaster Super 40 Exhaust, Engine Oil cooler w/ remote filter, In-roof 8" DVD, Profile 600 Watt Amp, Kenwood 6.75" 3-ways, NV242, 3.5" Lift, RS9000s, 31x10.50x15 ATs, Proline roof rack w/ spare tire mount and 4 Hella 550s.
Old 06-24-2005, 09:07 AM
nothing
Nothing is shown open. We've slammed all the doors multiple times - this doesn't do anything to reset it.
The weird thing is that if a door or something was open, or it thought one was, then the lights wouldn't go off when the Jeep is turned off. They do go off eventually after the jeep is turned off.
Old 06-24-2005, 09:14 AM
fredjacksonsan's Avatar
fredjacksonsan fredjacksonsan is offline
Caution: Monkeys bite!
Send a message via AIM to fredjacksonsan
How's your battery and positive cable? I've heard of weird electrical issues with a partially corroded positive battery cable. (happened to me).
Ours: 2020 Jeep Wrangler 2.0, 53k
2013 Toyota FJ Cruiser, 84k
Kids: 2005 Honda CRV, 228k
Old 06-29-2005, 02:28 PM
Audiobahn77 Audiobahn77 is offline
you more than likely have a bad door switch. Usually the driver's door switch too. You can disconnect the door switch by unscrewing the one screw and pulling it out. Disconnect it and see if the light goes out when you have it running. Do this on all the doors to see if it is a door switch. I had that problem and just swapped it out with a switch from the back door and left the one in the back disconnected. No problems since!
Old 06-29-2005, 04:37 PM
Disconnecting the battery and cleaning off the corrosion worked like a charm. Thanks fred.
Old 06-30-2005, 06:42 AM
Welcome - glad to help.
(Usually it IS the door switches, though)
