| Car Modeling Share your passion for car modeling here! Includes sub-forum for "in progress" and "completed" vehicles. |
What happened????
Ok so I'm working on my S2000 and I paint the body wait about a week and a half then i go to clear coat it and this happens
Clear coat is Rust Oleum paint is testors. Can anyone tell me what's going on??
Matt! \ ![]()
Re: What happened????
What type of paint is it you used for each coat? It's not something obvious like spraying a lacquer over enamel is it?
I used simple Emanal for each coat.
Matt! \ ![]()
ufff! comiserations.
It defiantely looks like some kind of chemical reaction from here - looks as if's "bubbled" up like when you use a paint stripper. Were both jars/cans you were using new? or had you used them both b4 on other kits? if new, maybe one of them was faulty? Or maybe something contaminated the surface of the model between coats and you didn't notice? spray anything in close proximity in between times? sad 4 you
Guideline for happy modeling: Practice on scrap. Always try something new. Less is more. "I have a plan so cunning, you could put a tail on it and call it a weasel" - Edmund Blackadder |
the clear is to agresive, for sure, if it's not what Phil said (clear being laquer) then the propelent in clear is to strong for the base colour.
Only solution, give it brake fluid bath and start over with other clear coat. |
Rustoleum, Krylon.... are all way too hot to apply over testors. Looks like this one is going for a dip in the purple pond!
Freakin' Groovin"
Damn I was hoping that this wouldn't come
This sucks. Ok thanks for the help, What about Tamiya clear will that work?
Matt! \ ![]()
No, Tamiya TS-13 over enamel will not work at all. You need to start again and stick to like paints, i.e. all lacquer or all enamel. There is plenty of info on paint types in the FAQ.
Ok thanks alot for the help. I'll go check the FAQ
Matt! \ ![]()
Warm your can! Thats the problem. Was the can cold?
~Josh~ OldUser:IImportSupra Do You Have a Car that Goez Sideways?
Warming the can will reduce "orange peel" but this looks like more than just that.
Josh- No the can was not cold it was warm.
No both cans were used before and checked every time used, Also what Brake fluid should I use DOT 3?
Matt! \ ![]()
Sorry to see what happened to your paint job. I dont know which type of brake fluid to use as I have never used it before myself and would like to know if there is a better type than others. Also, how do you clean the break fluid off afterward? Personally I use Castrol Super Clean (CSC). I've stripped plastic and resin and never had any parts damaged by the CSC. The one minor problem I had was the pigment of the original plastic was "bleached" abit on one car, but that was my fault I left it in the bath for like 2 weeks when I went on vaction. But the plastic is still strong, just kinda pink now instead of red.
You can use a toothbrush and scrub it off. I just take it that DOT3 is good.
Matt! \ ![]()
I have seen the same happen when using nail polish with an air brush with not enough air pressure. it appears to have reacted though.
