Old 06-23-2005, 02:51 AM
91camaro_rs 91camaro_rs is offline
Send a message via Yahoo to 91camaro_rs
91 camaro rs 3.1 still not running.
starts when it wants...more when its hot out. took it to a garage. said there was no pulse to the injectors. replaced the icm. started right up. ran all day. then quit. starts when it wants to. been doing it for 2 weeks. mostly wont start. mechanic said it could be the computer or the distributor. i dont know what to do. i replaced the plugs, wires, starter, ( was bad ) its getting the fuel pressure it needs. just seems like its losing spark or something. losing my freaking mind. please help
Old 06-23-2005, 02:52 AM
Re: 91 camaro rs 3.1 still not running.
Also the front brakes keep locking up...new calipers rotors and pads....???????????????? dont know what to do with them either
Old 07-17-2005, 05:38 PM
NINÅ's Avatar
NINÅ NINÅ is offline
Tricky Start, Sticky Stop
Originally Posted by 91camaro_rs
starts when it wants........Also the front brakes keep locking up.......
'Bout your first problem, your "mechanic" is just guessing, find another one. 'Bout your second, replace your calipers and the rubber brake hoses that connect your cals to your steel lines.
REFUSE
. . TO . . LOSE
Old 07-17-2005, 10:12 PM
ct91rs ct91rs is offline
Re: Tricky Start, Sticky Stop
Is the problem still that the injectors are not getting a pulse? If there is still no pulse to the injectors I would lean toward the ECM, but if it's a spark problem I would try replacing the pick-up coil first.
Old 07-18-2005, 12:56 AM
it was just the high pressure brake hose. fixed now...
