Go Back   Automotive Forums Car Chat > GMC > Jimmy
Old 06-22-2005, 11:57 PM
xrtdx8's Avatar
xrtdx8 xrtdx8 is offline
Send a message via Yahoo to xrtdx8 Send a message via Skype™ to xrtdx8
98 S15 Jimmy 4x4 problem
I have a 98 s15 jimmy. When i have it in 2wd and crank the wheel al the way to either side and accelerate a decent amount there's a small clunking. When i have it in 4wd and crank the wheel all the way to either side and accelerate it feels as though something were rubing against the tires and restricting movment, but there's nothing hitting the tires. Does anyone know what this problem might be?
Old 06-23-2005, 06:09 AM
kjknittel kjknittel is offline
You might have a problem...
I had the same problem. You could check a few things. Your hub and bearing assembly may be separating. If this is the case your ball joints may be failing as well. Check the seals on your ball joints and make sure they aren't blown. To replace your h & b your will need to break the axle nut loose and partially remove the brake caliper. This can be fairly involved. As for the trouble of turning in four wheel, that is perfectly natural. The range of operation in 4wd is limited and you don't want to max it out it can damage your drivetrain. Hope this helps.
Old 06-23-2005, 05:16 PM
xrtdx8's Avatar
Thanks, I just looked under my car at the front end, everythin seems to look ok, someone else told me the same thing with turning in 4wd, i tohught it was a new problem but i just may have never turned the wheel that much before. Just wanted to make sure my 4wd wasn't goin to quit when i'm usin it and me get stuck somewhere. THANKS again.
Old 06-27-2005, 12:09 PM
casualchris casualchris is offline
cv
possiable cv joint failure???
cc
