Old 06-22-2005, 11:14 PM
alphalanos alphalanos is offline
comp audio. only 1 channel working
ok another problem. my computers audio. it seems that only 1 channel (side) is working. first i thought one of the speakers just blew. but then i hooked up a good pair of headphones the the audio plug in the mother board and still only one channel (side). any ideas?
96 EJ6. Future home of boosted B18C1.
Old 06-23-2005, 12:39 AM
ec437's Avatar
ec437 ec437 is offline
Re: comp audio. only 1 channel working
do you have a soundcard or onboard audio?
SoStAsSaId: and the flight attendant is cute... if i was a lesbian, i'd join the mile high club
<---call this number
Old 06-23-2005, 01:26 AM
i dont have a soundcard
Old 06-23-2005, 03:25 AM
Neutrino's Avatar
Neutrino Neutrino is offline
Yaya Master
Send a message via AIM to Neutrino
just to clarify, you are having this problem with 1 one of the outputs? Most cads or even onboard audio support at least 5.1 systems with 2 stereo ouputs for front and back plus another for center and sub. Which one of those ouputs is giving you trouble?
Anyway just some basic stuff, make sure the conections are good then go in volume control and make sure you have the balance slider in the middle.
Also in controll panell>sound and audio devices>speaker settings>advanced you can set the type of soudsytem you are using. Use this unless you have another proprietary controll system that came with your sound.
Updating the drivers might also help.
(\__/)
(='.'=) This is Bunny. Copy and paste bunny into your
(")_(") signature to help him gain world domination
Old 06-23-2005, 10:09 AM
Knifeblade Knifeblade is offline
Start with the tweaks Neut. gave ya, could be as simple as that. Next, are the speakers and [presuming you have one, subwoofer] paralled wired to one plug only? Depending on th3 speakers, which you didn't give much info. about, most systems [speaker systems] start their connect off the subwoofer, which is usually separate-powered, and all in/output comes from the sub. connect to the audio in on your tower.
Old 06-23-2005, 11:16 AM
theyre just two desktop speakers with no subwoofer. they came with the Compaq mv540 monitor i am using and they have a power plug that plugs into the monitor. there is only one mini plug the goes into the computer(motherboard) which was working fine until recently. i havent switched anything around and all the volume controls are balanced in the middle. the right speaker picks up mechanical noise from my cd drive. kind of like a buzzing sound. but it doesnt play regular sound at all. the left speaker works fine.
Old 06-23-2005, 11:41 AM
The plug, dude, or give a quick shot of electronic spray cleaner into the tower connect. Power off, allow to dry, while plug/unplug, will open connects, hopefully. If not, the plug or its internal wiring. Plugs are flimsy, the wires break or short at times.
Old 06-23-2005, 10:07 PM
What the hell!!! i just came home...havent touched the computer at all. now the OTHER speaker works and the one the worked before doesnt. what the heck
Old 06-24-2005, 07:39 PM
zagrot zagrot is offline
Send a message via Yahoo to zagrot
uh-oh. you'll need a catholic priest to perform an exorcisim.
Old 06-29-2005, 03:00 PM
Da plug, Da plug
