Go Back   Automotive Forums Car Chat > Toyota > MR2/MR-S
Old 06-23-2005, 12:10 AM
greenjack greenjack is offline
mr2 Info
I am a newb here, and I tried the search a few times firts but it would not work so try not to get mad at my ignorance. I was just wondering what kind of swaps can you do in the sw20 series(NA or FI). And what are some good websites with parts for mr2's. Thanks-Jackson
Old 06-23-2005, 12:21 AM
MR2turbo93's Avatar
MR2turbo93 MR2turbo93 is offline
Re: mr2 Info
well you can swap the turbo motor into an NA and the 1MZFE V-6 into the NA or Turbo. if your outside the US thats about it .....but if in the US you can also swap the Beams 3SGE into them. But as in any car swaps aren't easy and being the MR2 is a mid engine car doesn't help. your better off buying a turbo but thats just this guys opinion
Check Out These:
- http://www.atsracing.net/
- http://www.mrcontrols.com/primers/power.htm
- http://www.koracing.net/products.html
- http://mr2oc.com/
- http://www.twosrus.com/
"In Reality we have this thing called physics. Respect it, or it will kick your ass."~ Dave Coleman
Old 06-23-2005, 12:45 AM
Re: mr2 Info
So I couldn't just put a turbo kit on the NA motor with bigger injectors or something, or stronger internals?
Old 06-23-2005, 12:13 PM
MR2turbo93's Avatar
Re: mr2 Info
you could ... i suppose but your better off buying a trubo..... The 3SGTE is a much better option that ripping down a 5SFE and building it up.... when you build a motor you'd better have a spare cause your looking at alot of down time... with a stock turbo you skip all of that
Old 06-23-2005, 04:28 PM
TRD2000's Avatar
TRD2000 TRD2000 is offline
Re: mr2 Info
why exactly can't you put a beams engine in a car outside the US?
Who needs AWD? i feel inspired by the original 911 turbo, my car will have more rubber sqeezed in its ass than Annabelle Chong! and it will go down as one of the greatest rides in history!
Old 06-23-2005, 06:13 PM
Re: mr2 Info
Is the beams motor a whole block you can just buy somewhere?
Old 06-23-2005, 08:52 PM
MR2turbo93's Avatar
Re: mr2 Info
you could i just ment you have the option to try and find/buy one
Old 06-23-2005, 08:53 PM
MR2turbo93's Avatar
Re: mr2 Info
plus there are many other 3SGE's outside the US to swap in
Old 06-23-2005, 10:23 PM
Re: mr2 Info
Where can you find them?
Old 07-07-2005, 01:40 PM
Deuce Is Wild Deuce Is Wild is offline
Re: mr2 Info
It's much cheaper buying a Turbo car right off the bat, but there's advantages of swapping a 3SGTE into a car that was originally an NA, generally there's a weight difference, the latter ending up a little lighter for some reason.
Also swaps can run into some $$$, it cost me over 1,250 just to bring my clip over from JP to the east coast, mostly because of warehousing fee's. I pretty much ripped the guy off on the clip so that made up for it, but in the end it cost over 3,000. Make sure you buy a quality clip, get one with as many usable parts as you can. My clip had very low mileage, but probably as a result of not only the average lifetime of cars over in JP is 30-50k miles, but the owner prematurely ending this short life expectancy being in an accident and ruined the driver's side wheel bearing, hub assembly and stabalizer bar. Try fixing minor accident damage and getting it inspected in JP - it will be a hoot with their strict standards. Anyway, I had to some brand new components and previous issues fixed, which attributed to the cost.
I now have a low mileage engine that is already otherwise bulletproof that runs 11's on the spray!
Old 07-07-2005, 06:47 PM
drazhartd drazhartd is offline
Re: Re: mr2 Info
Only something like 1000 beams motors were made, and thus have little to no aftermarket.
So even if you're lucky enough to find one... and have the $4000 to get it, you won't find parts for it too easily.
Now if you want power, go 3sgte. The 5sfe takes too much money.
For everything mr2, join mr2oc.com
91 MR2
Looking for Sparco steering wheel, or Momo Jet (black) wheel. Email pics, let's make a deal!
Old 07-07-2005, 06:55 PM
TRD2000's Avatar
Re: mr2 Info
if i was going beams i'd go black top Draz, where there IS aftermarket and there were a LOT more than 1000 made.
there were only 1000 red top single vvt MR2's.... don't know bout how many red top engines there were though...
Old 07-08-2005, 12:31 AM
MR2turbo93's Avatar
Re: mr2 Info
the celicas got the red tops also but i think the power is lower not sure.... and yes the plack top is crazy.....bob norwood set a land speed record with a MR2 Gen 2 with a turbo'd 4AGE 20 Valve and de-stroked it to compete in the 1.5L class .....needless to say it went 205mph!!! in a mile run
Old 07-10-2005, 03:00 PM
TRD2000's Avatar
Re: mr2 Info
that's a black top 4A-GE i mean the black top 3S-GE beams engine.
Old 07-11-2005, 12:28 AM
christo4_99's Avatar
christo4_99 christo4_99 is offline
Send a message via AIM to christo4_99 Send a message via Yahoo to christo4_99
Re: Re: mr2 Info
I read about that deal...very interesting read...i notoiced how all things considered he only lost 7mph or so with the non-ported head!
