Old 06-22-2005, 11:09 PM
ez1286's Avatar
ez1286 ez1286 is offline
Send a message via AIM to ez1286
RIP car
Today my car took an injury and will be out for the season, surprisingly it didn't happen sooner. This morning it started getting hot and it died as i turned into my work parking lot. On the drive home it started to get really hot again. I pulled over checked over things put some cold water in it then it had trouble starting and i knew there was a problem. I got home and did a compression test 110 80 90 120 and burning oil. It's done at least until i get back from AIT. But i will be buying a 90 gs-t in a few days and when i get back from AIT I'm putting a stroker kit in my talon.
95 GSX:FMIC, 6-bolt, evo 3 16g, 2600 act clutch, 1g bov (crushed), and a 3" turbo back exhaust, dsmlink, dks 272 cams, wideband 02, Coming soon 2.3L Stroker, 1mm oversized valves, crower sprigs. 91 TSI AWD auto, gm 3.5 maf, maft, fmic, emanage, profec e-01, 3" turbo bk exhaust +more little stuff.
http://www.ratemydsm.com/member/ez1286/?member=ez1286
Old 06-23-2005, 02:20 AM
drewh4386's Avatar
drewh4386 drewh4386 is offline
Send a message via AIM to drewh4386 Send a message via MSN to drewh4386 Send a message via Yahoo to drewh4386
Re: RIP car
Buy the gs-t...mod it....then give us times.
OH! and fix the talon.
....It has been a LONG time...I want to move to FL or Japan.....
Old 06-24-2005, 04:05 PM
ted_ex's Avatar
ted_ex ted_ex is offline
i plan on fixing the talon, but until thats done i'm not doing anything to the eclipse, by the way i bought the eclipse for $250, it has a bad ecu and i have one. The car is in really good shape, i got it last night and i still can't believe it was only $250!!!
I'm>everything
Old 06-24-2005, 04:10 PM
ez1286's Avatar
whoops i was in under my brother's name
Old 06-24-2005, 04:12 PM
drewh4386's Avatar
Re: RIP car
thats one of the weird things I've seen. Still git r done then everything will be ok.
Old 06-24-2005, 08:06 PM
gthompson97's Avatar
gthompson97 gthompson97 is offline
Send a message via AIM to gthompson97 Send a message via MSN to gthompson97
Re: RIP car
may i ask why you drove it when it kept getting hot?
95 Talon TSI AWD
97 Eclipse GST
Old 06-24-2005, 10:16 PM
macder macder is offline
Send a message via MSN to macder
Re: RIP car
Hot engine + Aluminium head + cold water = Cracked head (Logically)
Aluminium is not very forgiving to a sudden temperature change
1993 Eagle Talon ES (4g63NA)
14.6 @ 98 mph (110 octane race fuel)
-5 Speed Transmission (From a 4g67)
-Stage 2 Crane cams
-Ported and polished head
-Aggresive valve springs
-2.5" Custom made exhaust piping
-Custom header
-Gutted catalytic converter
-Bored 0.5mm
-Advanced ignition timing (CAS) aprox. 5 degrees (set @ ~10deg BTDC)
-2g valve lifters (Lifter noise returned, now it a true DSM)
-K&N w/modified air canister
Old 06-26-2005, 10:18 AM
ted_ex's Avatar
Re: RIP car
The car was already terminally ill when it started overheating. We knew the engine was not gonna last a whole lot longer anyway and he was driving it until he left for AIT. I am going to build the motor and paint the car while he is away over the summer. The 90 gs-t was such a bargain that we couldn't pass it up. It's in amazing condition with a new clutch, new alternator, and all service done. The thing even has all the little things missing from a lot of DSMs. It has the spark plug cover (unbroken), the timing covers are perfect, even the BOV cover is still on.
tedX
I'm>everything
