Go Back   Automotive Forums Car Chat > Oldsmobile > Eighty Eight
Eighty Eight Includes the '97-'98 Regency and '96-'99 LSS Models
Old 06-22-2005, 09:38 PM
savage_henry savage_henry is offline
'75 Delta won't start with turn of key
heres the situation.
my Olds runs, starts and everything. i just have to crawl under it and cross the posts on the starter with a screwdriver.
the problem is that when the key is turned, it wont even make so much as a sound.
so i cross the starter posts, use the key to unlock the column and then i can drive it anywhere i please.
i dont want to turn it into a demolition derby car quite yet and would prefer to drive it a bit longer, despite rising gas prices.
any help would be appreciated.
thanks.
Old 06-23-2005, 08:46 AM
tri-power's Avatar
tri-power tri-power is offline
Try replacing the ignition solenoid.
Old 06-24-2005, 04:29 PM
diesel1962 diesel1962 is offline
Re: '75 Delta won't start with turn of key
Hello.I had the same problem with a 1976 Oldsmobile.It was the iginition switch at the steering coloum.New switch cost me around $24.00you have to unbolt the steering coloum,And lower it down.It is bolted on top of the steering shaft.Unplug wire harness,replace switch.Good Luck..Diesel1962
