Old 06-22-2005, 09:29 PM
strk500 strk500 is offline
Send a message via AIM to strk500
Brake ????
I'm tring to do a brake job on my car and was wounder if you need to drain the brake fluid out before changing the pads and rotors??? does anyone have pictures of it on how to do it. I'm working on the rears first since they are squeeking.
Old 06-22-2005, 11:57 PM
Well i hope it was o.k to just push the piston back in without bleeding out the lines. But my next problem is, after installing the pads i can't slip it back over the rotor and the piston is in as far as it goes... any ideas??
Old 06-23-2005, 05:33 AM
GTP Dad GTP Dad is offline
Pontiac Guy
Re: Brake ????
Are you absolutely certain the piston is in all the way? There are only a couple other items I can think of that would cause this. Wrong pads, wrong rotors or pads not totally seated in the calipers. If everything else is correct then they should go on properly.
As for the brakes, if you have anti-locks you should avoid pushing the old brake fluid back in to the system. It can damage the ABS components due to dirt being forced into the ABS system.
Old 06-23-2005, 09:28 AM
I checked all the part #'s and they are for my car... I have Hawk pads and brembo rotors. and a 02 GTP
Old 06-25-2005, 09:42 PM
S13Sil40 S13Sil40 is offline
Re: Brake ????
if you look at the piston, it has two sort of grooves. The pad has little bumps that stick out a few mm. One of these bumps actually goes into the groove on the piston. My piston was twisted, so i took a screw driver and a rubber mallet, and rotated the piston so that the groove lined up with the bump.
worked like a charm.
