Old 06-22-2005, 08:39 PM
sLADe781 sLADe781 is offline
Power Tools
Do you guys know if stores have those type of power tools that can screw/unscrew lug nuts and other stuff for us to buy? We're planning on getting one to make repairs go by faster (yeah, we're getting lazy) and was wondering if they're available? Or is it only available for shops? Which ones are good and which onces should we stay away from? Thanks.
Old 06-22-2005, 08:43 PM
talskinyguy talskinyguy is offline
Send a message via AIM to talskinyguy
Re: Power Tools
You would be talking about air tools. What you need is an air compressor and then whatever air tools you want. I picked up a 33 gallon with a 6hp motor compressor for 300 and it came with 3 tools at sears. Just about any hardware store will carry them.
A few "bolt on" mods, a couple "cut, smash, hammer, weld, etc" mods, and a couple "why the hell do I need this/what the hell is this" weight reductions.
Old 06-22-2005, 09:59 PM
Hotshot8792 Hotshot8792 is offline
Re: Re: Power Tools
hey, i got that same air compressor with the same tools, man that thing is the bomb.
But, a cheaper alternative is to go to harbor freight and buy a 25 inch breaker bar for like 8 bucks, you'll be amazed what kind of bolts you can break off with that thing.
Daily Driver: 2004 Jeep Grand Cherokee Special Edition
1994 Mitsubishi 3000GT SL-TT Automatic - Black
3.05 L Arias Forged Pistons, Pauter Forged Rods, DR Stage 3 heads, 3SX TD05 kit w/ E16G's, CX Racing FMIC, 550cc injectors, Walbro 255lph pump, + supporting mods
1994 Mitsubishi 3000GT VR-4 - Black
Intake & Boost Controller so far
2006 Sea-Doo RXP Supercharged, Updraded SC, IC + supporting mods
Old 06-23-2005, 02:41 AM
Re: Re: Re: Power Tools
You mean one of them super big wrench stuffs? Hmm....maybe we'll try that alternative first then. Hehe But yeah, okay, I'll look into Sears too. Thanks guys!
Old 06-23-2005, 03:12 AM
Re: Power Tools
cheeper than that is to go to menards and buy 10ft of pipe, instant breaker bar, and you can cut it shorter if desired. You have missed the point, an 8ft breaker bar does not fit where an impact wrench can go, and will often actually break things that an impact wrench with take off.
Old 06-23-2005, 11:56 AM
Linebckr49's Avatar
Linebckr49 Linebckr49 is offline
Send a message via AIM to Linebckr49
Re: Power Tools
auto zone will rent tools to you. not sure if they rent air tools or not, but you can check. if so, then you would just need to find a friend and borrow his air compressor.
93 3000GT base
K&N | long tube headers | 3sx crank pulley| testpipe | Addco front/rear sway bars (3SX) | rear strut bar & front 3-point strut bar (by JonVr4 on 3Si) | solid motor mounts | LSD insert | KYB GR-2 struts | intrax springs | adj. control arms | ss brake lines | 16% taller 5th gear (teamrip.com) | H4 conversion | push-button start | datalogger | HKS S-AFR | PLX WB O2
coming soon: adj. cam gears | bi-xenon HID retrofit
Old 06-23-2005, 06:58 PM
Re: Re: Power Tools
Ah, got it! No, I don't want that then....I need the stuff that I take off still.
Old 06-23-2005, 10:32 PM
i haven't broken anything yet with my breaker bar, and in some instances, it can be very useful.
For example, when i changed out my motor mounts. The rear one, i could not fit my impact down in there, so i was able to break it off with my breaker bar. Also, my side motor mount nuts were on soo tight that my impact wrench couldn't even break them off but it didnt give any problems for the breaker bar, it broke them right off. Its often good to have the best of both worlds, sometimes its better to have a breaker bar and sometimes its better to have an impact wrench, all depends on what your trying to do.
Old 06-24-2005, 05:38 AM
Re: Power Tools
extentions and a 1000ft lb impact wrench, done
Old 06-24-2005, 05:11 PM
Linebckr49's Avatar
Re: Re: Power Tools
ahh yes...a rail gun
93 3000GT base
