Go Back   Automotive Forums Car Chat > Honda > Let's get Technical!
Let's get Technical! Discussion for hardcore in-depth motor heads!
Old 06-22-2005, 06:45 PM
crabby760 crabby760 is offline
Compression Too High Overheat?
i have like 14:3 compression
d16y8 single cam vtec motor ALL MOTOR SET UP
my car doesn't ping or anything
but after like 25 mins of driving the car will get super hot and the temp needle will shoot up like right below the HOT... if i turn the heater on and let the hot air blow through the vent's it goes back to the middle then it'll fluctuate between middle and hot....
people teling me i need to lower the compression by getting a thicker headgasket
curious if there's other ways to prevent this from happening?
all fluids are good also and new thermastat
Old 06-22-2005, 07:28 PM
Greenblurr93's Avatar
Greenblurr93 Greenblurr93 is offline
Kind of a Big Deal
Send a message via MSN to Greenblurr93
Re: Compression Too High Overheat?
what kind of radiator are you running??? get an aluminum one and that should help a bit.
Old 06-22-2005, 09:42 PM
stock radiator....
Old 06-22-2005, 10:17 PM
knorwj's Avatar
knorwj knorwj is offline
Send a message via AIM to knorwj
is your water pump functioning properly?
Old:
1993 Acura integra gs-r
New:
1998 chevy BlaZeR2~ AKA "Jeep recovery device"
Newer:
2007 Honda CB900F "919"
Old 06-22-2005, 10:24 PM
i do not know... how do i check this?
Old 06-23-2005, 12:19 AM
if anyone has any ideas please tell me and let me know how to check it or fix it... thank you need to know ASAP
Old 06-23-2005, 01:29 AM
Kven's Avatar
Kven Kven is offline
have you tried changing the thermostat?
HondaSwap | K20A.org | EF Honda
1988 Honda CRX DX
WTB: CRX mudflaps(both front and rear)...PM me if you have some for sale!!!
Old 06-23-2005, 01:33 AM
flushed and refilled all fluids.... put in a new 170 degree thermastat
Old 06-23-2005, 07:40 AM
Kind of a Big Deal
could be a bad water pump or bad radiator.
