Old 06-22-2005, 05:33 PM
omaro86 omaro86 is offline
Vac reduction/egr blockoff
I'm going to have EGR blockoff plates here within the week, iv'e been searching but can't really find everything. After the blockoff plates are installed I can take out All the hoses from the spiderweb right? Also what can I remove from the firewall? what else can i remove if there is already a MBC insalled? sorry for all the newb questions that probably have been asked before it's just kind if intimidating with all the damn vaccume hoses, just want to make sure I don't take out something I need. pics would be very helpfull if anone has any.
thanx in advance.
Old 06-22-2005, 09:50 PM
Hotshot8792 Hotshot8792 is offline
Re: EGR blockoff
The EGR block offs have nothing to do with the spiderweb. They just let you remove your EGR valve. You can get rid of your spiderweb by doing the vacuum reduction mod at any point you want to. There should be some instructions on stealth316
thanx in advance.
Daily Driver: 2004 Jeep Grand Cherokee Special Edition
1994 Mitsubishi 3000GT SL-TT Automatic - Black
3.05 L Arias Forged Pistons, Pauter Forged Rods, DR Stage 3 heads, 3SX TD05 kit w/ E16G's, CX Racing FMIC, 550cc injectors, Walbro 255lph pump, + supporting mods
1994 Mitsubishi 3000GT VR-4 - Black
Intake & Boost Controller so far
2006 Sea-Doo RXP Supercharged, Updraded SC, IC + supporting mods
Old 06-23-2005, 04:44 PM
turbo ES turbo ES is offline
Re: EGR blockoff
why would you want to block it off? whats the advantage
Old 06-23-2005, 05:52 PM
Re: EGR blockoff
sorry i just read the faq and got my answer. is it worth it though i cant imagine its getting enough bad air to notice it when its off correct me if im wrong
Old 06-23-2005, 10:27 PM
Re: Re: EGR blockoff
the block off plates are only like 20 bucks, and it just removes the EGR valve. You wont feel a difference, and you might get 1 hp, but its basically removing stuff that deals with emissions. It also allows 1 less thing to do anytime you have to do work in your car that involves pulling the intake plenum.
Old 06-24-2005, 06:48 PM
Igovert500's Avatar
blue + red light magnet
Re: EGR blockoff
You wont gain any hp at wide open throttle, because the EGR is closed at this time anyway. However, it is one less damn thing in the way to remove when taking off the intake plenum as said before, and it also keeps your intake alot cleaner...less carbon buildup.
96 3000gt vr4
-K&N FIPK
-Proboost mbc
-Greddy type-s
-ATR downpipe
-no cats
Old 06-25-2005, 06:40 PM
Alright, Iv'e been reading about the vac reduction, and i'm planning on doing that now too, but iv'e got a few q's. since iv'e got mbc installed already, i can remove the stock bost solinoid, but do you just leave the harneses that go to the solinoids hanging there or what? what else can i remove besides stock boost solinoid? Also does anyone have any pics of the firewall/spiderweb area after the reduction, would be of great help. you can do van reduction without doing the egr blockoff first right?...just leave the egr solinoid on?? and One more thing, After the reduction what are my chances of still passing IL emissions? last time i passed with FLYING colors. thanks again.
Old 06-25-2005, 06:59 PM
mike93vr4's Avatar
mike93vr4 mike93vr4 is offline
Re: EGR blockoff
um whats the point of the vacuum reduction mod?
Old 06-25-2005, 07:05 PM
To get rid of 75% of all thoes vaccume lines under your hood.
Old 06-25-2005, 07:11 PM
mike93vr4's Avatar
Re: EGR blockoff
so how does that make more power or does it?
Old 06-25-2005, 07:20 PM
You won't make more power, it's purpose is to clean up the engine bay. and also make it alot eaiser to work under there. The only way it could give you more power would be because it's eliminating more places for boost leaks to show up.
Old 06-25-2005, 07:29 PM
mike93vr4's Avatar
Re: EGR blockoff
o ok
Old 06-28-2005, 06:08 PM
anyone??
Old 06-28-2005, 08:12 PM
Re: Re: Re: EGR blockoff
right, its supposed to help prevent possible future boost leaks in that mess
Old 07-03-2005, 02:46 PM
Alright Im in the middle of doing this now but have some questioins.
-Pic #1 I can rip this out and all hoses with it and cap right?
-Pic #2 The 2 with the arrows get capped?
-Pic #3 in this pic the gold fitting is my boost gauge, but i thought everyone else had their gauge spliced into the small vaccume hose right there on the plenum, is mine ok? and also if it's ok, I can just cap that nipple on the plenum right?
also all 4 solinoids on the firewall can be removed?
I think i might do some type of write up on this for anyone else with questions, because I had some trouble finding all the info I needed.
Thanks.
