Old 06-22-2005, 04:12 PM
dycksonjl dycksonjl is offline
A/C freon level
Can you tell by looking at the sight window if there is enough freon in your A/C system? I can see fluid flowing...should I???
Old 06-22-2005, 04:23 PM
Saudade's Avatar
Saudade Saudade is offline
Re: A/C freon level
Yes you should. Bubbles would indicate an undercharge. Do not attempt to go by the sight glass if you try to recharge the system. Use gages or take it somewhere.
Old 06-22-2005, 05:18 PM
The A/C isn't cooling. It blows hot air. Would it be safe to add a pound of freon?
Old 06-23-2005, 01:02 PM
AlohaBra's Avatar
AlohaBra AlohaBra is offline
Re: A/C freon level
You can buy a recharge kit that has a color coded gage for the low side for $40.00. Make sure the compessor clutch is coming on or jump it first. Otherwise, the pressure will be too high when you hook up and cause rerigerant leakage.
Old 06-24-2005, 04:55 PM
The recharge kit....is it for R12? Where can i get one?
Old 06-25-2005, 11:07 AM
Saudade's Avatar
Re: A/C freon level
Techincally speaking, you can not buy R12 unless you're EPA certified. Having said that, you can find lot's on eBay.
Beware of the R12 substitutes. Not saying they're bad, but you may need to change out other parts to complete the swap.
