Go Back   Automotive Forums Car Chat > Ford > Thunderbird
Old 06-22-2005, 03:26 PM
ScottG29 ScottG29 is offline
Send a message via AIM to ScottG29 Send a message via Yahoo to ScottG29
Exclamation Thumping and vibration problem
Okay guys this one has me totally stumped. I have a 96 Thunderbird LX sport. 69,000 Miles. I have 2 problems which seem to be from the same thing. First of all during hard acceleration or going over bumps there is a loud thumping from the rear end. Also, from 50 mph - 90mph there is a horrible vibration. It is best felt from 70-75mph. The vibration is very severe and seems to be from the rear of the car. But the vibration can be felt throughout the entire car. Floorboards, steering wheel, seats, dashboard, ect. I have had the tires balanced twice. Once by myself and once by belle tire. And I have also replaced the IRS bushings (they were worn out, but did not stop the problem). Please help!!
Scott G
1996 Thunderbird LX Sport V-8
Old 06-22-2005, 05:00 PM
SVTBIRD's Avatar
SVTBIRD SVTBIRD is offline
Send a message via AIM to SVTBIRD Send a message via Yahoo to SVTBIRD
first of all, the thumping is most likely the upper shock bushings. i had the same problem on my 93 5.0 with only 70,000 miles. the upper shock bushing has 2 parts, the top of the lower one tends to get worn out allowing the shock to rattle in all directions. when you go over a bump the loose shocks thump like crazy.
you can check the bushing by jacking up the car by the frame until the shock is not in any tension/compression and try to rattle it around side to side, if it does, then that's what it is. you can also take the shock off the lower mount so it's just hanging by the upper and try rattling it. if this is the case, i would suggest new shocks, but just the bushing isn't that hard to find if you don't wanna drop the money. if the bushing isn't too worn, you may be able to space it with a washer on top of the upper busing but this is a band-aid.
this play in the shock could have some effect on the vibration of the car, as the suspension is allowed to travel for a short distance with no damping.
if that's not it, check for:
unbalanced driveshaft
bad wheel bearings
cheap tires (winstons are notorious for becoming unbalanced)
bad pinion/halfshaft bearings (will cause bad diff leaks too)
proper backlash on ring/pinion gear (find someone who knows what they're doing)
hope i helped
I drive way too fast to worry about cholesterol
"If everything seems under control, you're not going fast enough." - Mario Andretti
I couldn't repair your brakes, so I made your horn louder.
Old 06-22-2005, 06:37 PM
97Bird's Avatar
97Bird 97Bird is offline
Re: Thumping and vibration problem
Check the driveshaft u-joints.
Old 06-26-2005, 10:20 PM
flewthecoupe's Avatar
flewthecoupe flewthecoupe is offline
cv joints is something else to check
It's not how fast you can go, it's how fast you can get there.
Proper grammar, it's not just for English teachers.
I don't pick on any one person, I treat everyone this way.
My only pleasure is tormenting those people who work for me.
There are no stupid questions, just a lot of inquisitive idiots.
Old 07-31-2005, 10:20 PM
Spoon134 Spoon134 is offline
Send a message via AIM to Spoon134 Send a message via Yahoo to Spoon134
I have a 96 t-bird with the same problem and I have tried everything from putting a new rearend into the car.I still get that vibration around 65-75mph.If anyone has figured out what this problem is please email me, Thanks!
Old 08-02-2005, 08:43 AM
94tbirdlx2005 94tbirdlx2005 is offline
Send a message via Yahoo to 94tbirdlx2005
I had a loud thump, and there was a bushing missing from the stud holding the rear end. Replaced it, and haven't felt a vibration or thump from 0-125.
