Go Back   Automotive Forums Car Chat > Honda > Integra
Old 06-22-2005, 02:43 PM
paliagp paliagp is offline
will my tranny bolt up to my new engine???
hey guys,
i have a 90 integra rs/auto and im getting a b16a very soon.im really strapped for $$$ right now so im gonna hold off on doing a standard conversion for now.Will my auto tranny bolt up to a b16a because i think that any ls tranny will bolt up to any b series engine but im not too sure on that one.any input on this would be great......
Old 06-23-2005, 01:02 AM
Rgacke's Avatar
Rgacke Rgacke is offline
Re: will my tranny bolt up to my new engine???
Yes it will bolt up.
"shut the door Joshua, and let death pass by..."
Old 06-23-2005, 07:32 AM
Schister66's Avatar
Schister66 Schister66 is offline
AF -Advisor
Send a message via AIM to Schister66 Send a message via MSN to Schister66
it will but why would you want an auto??
2015 DGM STi - 2006 SGM STi - 1999 Built/boosted GSR
Old 06-23-2005, 09:21 AM
no, dont get me wrong, i want standard but the standard swap has to wait for now because im low on cash, but i should have it done within a couple of months i have a few other questions about this matter.....1)is the b16 a direct connetion with no rewiring and can i use the original wiring harness??
2)do all the sensors match wiring harness(if im able to use the old harness??
3)do all my old accesories bolt up to my new engine like the alternator,water pump, etc......
THANKS FOR ALL YOUR INPUT!!!!
Old 06-23-2005, 02:56 PM
Rgacke's Avatar
Off the top of my head, the only wiring you will have to do is run two wires for vtec, but check into it just to make sure. You will need ecu harness pins for these wires, got to a junk yard and just cut the harness/remove the pins.
Removing the pins from the plastic harness is not easy the first time you do it. You need a very small flat screw driver. Theres a piece of plastic that you have to push down from the ecu side of the harness.
Old 06-23-2005, 06:26 PM
thanks for that info, ive heard someone else say something like that too.....anyways, this might sound like a stupid question but is my car obd0 or obd1...its a 90 acura integra rs......and would it be worth it to get a harness from rywire for my new b16 or should i modify my harness for the vtec??
Old 06-24-2005, 10:16 AM
Rgacke's Avatar
Your car is OBD0. What B16 are you getting? Honda made that engine from 1988-2000 so theres quite a few versions. The most available/cheapest ones are the B16a1 from crxs/integras.
Getting a new harness is not worth the time VS. $$ of running two wires.
Old 06-24-2005, 08:06 PM
well, since my car is obd0 i guess a b16a would be the best match. I was looking at some wiring diagrams for the vtec and there was the vtec solinoid,vtec oil pressure, the knock sensor, and the O2 sensor.rywire sells a conversion kit for this and its plug and play for 55$ american.has anyone got anything from rywire and if so, were you satified with what you got.
